AWstats Problem - awstats.pl missing
V
varet
I am getting the following problem:
sh: /var/www/cgi-bin/awstats/awstats.pl: No such file or directory
sh: /usr/share/awstats/awstats_buildstaticpages.pl: No such file or directory
statistics: Unable to execute /usr/share/awstats/awstats_buildstaticpages.pl -awstatsprog=/var/www/cgi-bin/awstats/awstats.pl -configdir=/usr/local/psa/etc/awstats -config=cwstext.gr-http -dir=/var/www/vhosts/cwstext.gr/statistics/webstat/current
System error 2: No such file or directory
statistics: Unable to execute /usr/share/awstats/awstats_buildstaticpages.pl -awstatsprog=/var/www/cgi-bin/awstats/awstats.pl -configdir=/usr/local/psa/etc/awstats -config=cwstext.gr-https -dir=/var/www/vhosts/cwstext.gr/statistics/webstat-ssl/current
statistics: Unable to execute /usr/share/awstats/awstats_buildstaticpages.pl -awstatsprog=/var/www/cgi-bin/awstats/awstats.pl -configdir=/usr/local/psa/etc/awstats -config=cwstext.gr-anon_ftp -dir=/var/www/vhosts/cwstext.gr/statistics/anon_ftpstat/current
statistics: Unable to execute /usr/share/awstats/awstats_buildstaticpages.pl -awstatsprog=/var/www/cgi-bin/awstats/awstats.pl -configdir=/usr/local/psa/etc/awstats -config=cwstext.gr-ftp -dir=/var/www/vhosts/cwstext.gr/statistics/ftpstat/current
I searched for these:
/usr/share/awstats (does not exist)
/var/www/cgi-bin/awstats (does not exist also)
I tried to reinstall package: psa-awstats-configurator (but seems not to fix the problem)
Plesk: 9.5.3
OS: Centos 5.4
Any suggestion?
I Resolved the issue by removing awstats & psa-awstats-configurator.
After i reinstalled from Parallel's repo these two apps.
I have the same issue, but what do you mean with removing awstats and psa-awstats-configurator? Where can I find this? And how do I get the packages from Parallels repo?
