can´t execute pleskrestore / bash error: /usr/local/psa/bin/sw-engine-pleskrun
C
ChrisE@
After reinstalling Plesk 9 everything seems to work fine.
But, executing /usr/local/psa/bin/pleskrestore produces following error message:
Code:
servername:/ # /usr/local/psa/bin/pleskrestore
bash: /usr/local/psa/bin/pleskrestore: /usr/local/psa/bin/sw-engine-pleskrun: bad interpreter: No such file or directory
I´ve uninstalled all sw* packages and reinstalled them. But the error message still appears. When I take a look into the /usr/local/psa/bin/ directory, there is no "sw-engine-pleskrun".
A locate for "sw-engine" gets following result:
Code:
servername:/ # locate sw-engine
/usr/bin/sw-engine
/usr/bin/sw-engine-cgi
/usr/local/psa/tmp/sw-engine-8880.sock-0
/usr/local/psa/tmp/sw-engine.sock-0
When I take a look at the pleskrestore file, first two rows are:
Code:
#!/usr/local/psa/bin/sw-engine-pleskrun
<?php
The pleskbackup file works fine. Do any of you have an idea how to solve this problem?
Thanks a lot.
Christian
