cgi and cgi-bin problems with plesk 7.5.4
M
mcfly
Hi @ all
I have now a new Server with Plesk and i will transfer my domains to this server.
My Problem is that i have a lot of domains and subdomains with cgi´s and i must have so that i can open aud execute cgi at all directories.
What must i do that i can that do it in all directories of domains and subdomains.
if found a help in the sw faq
How do I enable cgi-scripts to run from the both httpdocs and httpsdocs directories?
CGI scripts can be run in httpdocs/httpsdocs with mod_perl. You should enable mod_perl for a domain in Plesk CP and uncomment the cgi-script AddHandler directive in the Apache configuration file /$HTTPD_CONF_D/httpd.conf.
AddHandler cgi-script .cgi
Restart Apache.
can i make it so that this is always when I make a domain?
Sorry for my bad English. I hope anybody can help me.
When configuring the "physical hosting" portion of the domain setup, there is a checkbox titled "Mod_Perl" and another titled "CGI-BIN". Checking both of these boxes on any domain you create would enable the cgi-bin and mod_perl options you are interested in.
I know and it is on all domain´s but it doesn´t function in all directories. I want that the cgi´s ar started in all directories and not only in the cgi-bin directory.
Also i want to change the cgi-bin directory in the directory httpdocs. but with all reloads the directory stands on the old directory
