Issue Control Panel Certificate not working
appdesign
Hi, I am having a problem with the certificate, only when I access the plesk panel. The domain www.mypanelexample.com has correct SSL certificate and it shows correctly but when I access to plesk through www.mypanelexample.com:8443, the certificate is not correct and I can't access.
Someone with the same problem, it seems to be the problem of some update since I have not reset any certificate and in the domains it works correctly.
Thanks, i fix it just with:
  1. Make sure that the email address in the “Email address” field is correct and i change domain too. This email address will be used to send important notifications.
