Resolved Control Panel does not work
nebuzzer
Hello,
last night my server shuts down and after a restart nothing works fine. I cannot connect to my Control Panel, but everything else seems to work fine(domains, mail ...).
i already tried to bootstrapper. the results below
Code:
[2016-10-13 16:27:37] ERR [extension/wp-toolkit] Fehler bei der Ausführung von /opt/psa/admin/plib/modules/wp-toolkit/scripts/post-install.php. Der Exitcode lautet 1 und die Ausgabe ist: [2016-10-13 16:27:37] ERR [extension/wp-toolkit] Die geplante Aufgabe existiert bereits.
[2016-10-13 16:27:39] ERR [panel] Fehler bei der Ausführung von /opt/psa/admin/plib/modules/wp-toolkit/scripts/post-install.php. Der Exitcode lautet 1 und die Ausgabe ist: [2016-10-13 16:27:37] ERR [extension/wp-toolkit] Die geplante Aufgabe existiert bereits.:
0: /opt/psa/admin/plib/Extension/Package.php:505
    Plesk\Extension\Package->_scriptExecute(string 'wp-toolkit', string '/opt/psa/admin/plib/modules/wp-toolkit/scripts/post-install.php', array)
1: /opt/psa/admin/plib/Extension/Package.php:291
    Plesk\Extension\Package->_postInstallScript(object of type SimpleXMLElement, NULL null)
2: /opt/psa/admin/plib/Extension/Package.php:120
    Plesk\Extension\Package->install(string '/opt/psa/var/wp_toolkit_upgrade.zip')
3: /opt/psa/admin/plib/Upgrade/Task/17.0.15/2016-07-20-04-59-45_MigrateWordPress.php:23
    Plesk\Upgrade\Task\MigrateWordPress->upgrade(object of type Plesk\Upgrade\Deferred)
4: /opt/psa/admin/plib/Upgrade/Executor/Sync.php:15
    Plesk\Upgrade\Executor_Sync->upgrade(string '2016-07-20-04-59-45', object of type Plesk\Upgrade\TaskLoader, object of type Plesk\Upgrade\Deferred)
5: /opt/psa/admin/plib/Upgrade/Command/Task.php:46
    Plesk\Upgrade\Command_Task->run(string '2016-07-20-04-59-45', string 'upgrade')
6: /opt/psa/admin/plib/Upgrade/upgrade.php:19
taskId=2016-07-20-04-59-45 step=upgrade result=1 message=ERROR: PleskUserException: Fehler bei der Ausführung von /opt/psa/admin/plib/modules/wp-toolkit/scripts/post-install.php. Der Exitcode lautet 1 und die Ausgabe ist: [2016-10-13 16:27:37] ERR [extension/wp-toolkit] Die geplante Aufgabe existiert bereits. (Package.php:505)
Some steps of upgrade failed. Run upgrade with option --repair to rerun failed steps.
taskId=2016-07-20-05-34-06 step=upgrade result=0 message=
taskId=2016-07-20-10-09-33 step=upgrade result=0 message=
taskId=2016-07-22-08-17-06 step=upgrade result=0 message=
taskId=2016-07-27-18-01-01 step=upgrade result=0 message=
taskId=2016-08-04-14-02-00 step=upgrade result=0 message=
taskId=2016-08-26-03-21-02 step=upgrade result=0 message=
taskId=2016-09-07-14-00-00 step=upgrade result=0 message=
taskId=2016-09-21-15-49-41 step=upgrade result=0 message=
[2016-10-13 16:28:07] ERR [extension/wp-toolkit] Fehler bei der Ausführung von /opt/psa/admin/plib/modules/wp-toolkit/scripts/post-install.php. Der Exitcode lautet 1 und die Ausgabe ist: [2016-10-13 16:28:07] ERR [extension/wp-toolkit] Die geplante Aufgabe existiert bereits.
[2016-10-13 16:28:07] ERR [panel] Fehler bei der Ausführung von /opt/psa/admin/plib/modules/wp-toolkit/scripts/post-install.php. Der Exitcode lautet 1 und die Ausgabe ist: [2016-10-13 16:28:07] ERR [extension/wp-toolkit] Die geplante Aufgabe existiert bereits.:
0: /opt/psa/admin/plib/Extension/Catalog.php:230
    Plesk\Extension\Catalog->upgradeInstalledExtensions()
1: /opt/psa/admin/plib/Upgrade/Action/UpgradeExtensions.php:9
    Plesk\Upgrade\Action_UpgradeExtensions->run()
2: /opt/psa/admin/plib/Upgrade/Deferred.php:31
    Plesk\Upgrade\Deferred->run()
3: /opt/psa/admin/plib/Upgrade/Command/Upgrade.php:63
    Plesk\Upgrade\Command_Upgrade->run(boolean true)
4: /opt/psa/admin/plib/Upgrade/upgrade.php:27
ERROR: PleskMultipleException: Fehler bei der Ausführung von /opt/psa/admin/plib/modules/wp-toolkit/scripts/post-install.php. Der Exitcode lautet 1 und die Ausgabe ist: [2016-10-13 16:28:07] ERR [extension/wp-toolkit] Die geplante Aufgabe existiert bereits. (Catalog.php:230)
WARNING!
Some problems are found during execute post install/upgrade actions(see log file: /var/log/plesk/install/plesk_17.0.17_repair.log)
/var/log/sw-cp-server/error_log
Code:
2016/10/13 10:16:03 [crit] 3022#0: *1 connect() to unix:/var/run/sw-engine.sock failed (2: No such file or directory) while connecting to upstream, client: ::1, server: , request: "POST /check-plesk.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/sw-engine.sock:", host: "localhost:8443"
2016/10/13 11:18:00 [crit] 3024#0: *1 connect() to unix:/var/run/sw-engine.sock failed (2: No such file or directory) while connecting to upstream, client: ::1, server: , request: "POST /check-plesk.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/sw-engine.sock:", host: "localhost:8443"
2016/10/13 11:57:25 [crit] 3044#0: *1 connect() to unix:/var/run/sw-engine.sock failed (2: No such file or directory) while connecting to upstream, client: ::1, server: , request: "POST /check-plesk.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/sw-engine.sock:", host: "localhost:8443"
2016/10/13 12:03:27 [crit] 3030#0: *1 connect() to unix:/var/run/sw-engine.sock failed (2: No such file or directory) while connecting to upstream, client: ::1, server: , request: "POST /check-plesk.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/sw-engine.sock:", host: "localhost:8443"
2016/10/13 13:03:21 [warn] 29455#0: invalid parameter "spdy": ngx_http_spdy_module was superseded by ngx_http_v2_module in /etc/sw-cp-server/conf.d/plesk.conf:4
2016/10/13 13:03:21 [notice] 29458#0: using inherited sockets from "7;8;9;10;11;"
2016/10/13 13:03:21 [warn] 29458#0: invalid parameter "spdy": ngx_http_spdy_module was superseded by ngx_http_v2_module in /etc/sw-cp-server/conf.d/plesk.conf:4
nginx: [warn] invalid parameter "spdy": ngx_http_spdy_module was superseded by ngx_http_v2_module in /etc/sw-cp-server/conf.d/plesk.conf:4
2016/10/13 13:06:00 [crit] 29460#0: *1 connect() to unix:/var/run/sw-engine.sock failed (2: No such file or directory) while connecting to upstream, client: ::1, server: , request: "POST /check-plesk.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/sw-engine.sock:", host: "localhost:8443"
2016/10/13 16:23:13 [notice] 2869#0: using inherited sockets from "7;8;9;10;11;"
2016/10/13 16:24:26 [notice] 3032#0: using inherited sockets from "7;8;9;10;11;"
2016/10/13 16:32:26 [crit] 3047#0: *1 connect() to unix:/var/run/sw-engine.sock failed (2: No such file or directory) while connecting to upstream, client: ::1, server: , request: "POST /check-plesk.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/sw-engine.sock:", host: "localhost:8443"
