    CentOS2Alma discussion
Current backup tasks problems
F
FranckT
I have 4 old backup task on the "current backup tasks" page.
How can i delete this ?
The task progress is 89 % When I try to open the task i get "Error: Unknown object type".
My server use Centos 5.
Thanks in advance,
Franck Timbert
Try to kill all pmm or backupmng tasks first and then remove records about these backup tasks from 'BackupsRunning' psa database table.
Same problem here; I did what you suggest, but it is still on the plesk panel.
mysql> select * from BackupsRunning;
Empty set (0.00 sec)
mysql>
Like abdicarcomm, the suggestions from IgorG didn't work for me.
This worked for me:
1. Change directory to /opt/psa/PMM/tasks
2. Delete the file that has the timestamp which corresponds to the running task
