DNS problem domain creation & removing Failed
T
ton-pis
please, Help me
Failed domain creation: Unable to update domain data: Unable to create dnsmng object: dnsmng failed: Empty error message from utility.
---------------------- Debug Info -------------------------------
0: plib\ui_common\DomainPropertiesUIPointer.php:250
DomainPropertiesUIPointer->accessItem_create(string 'POST')
1: plib\ui_common\DomainPropertiesUIPointer.php:62
DomainPropertiesUIPointer->accessItem(string 'POST', NULL null)
2: plib\UIPointer.php:599
UIPointer->access(string 'POST')
3: htdocs\plesk.php:42
Problems occured while removing domains: dnsmng::remove() failed: dnsmng failed: Empty error message from utility.
0: plib\class.Client.php3:628
Client->removeDomains()
1: plib\class.Client.php3:670
Client->remove()
2: plib\ui_common\ClientDeleteUIPointer.php:61
ClientDeleteUIPointer->accessItem(string 'POST', NULL null)
3: plib\UIPointer.php:599
4: htdocs\plesk.php:42
We're having the same exact problem after upgrading from Plesk 9.1 to Plesk 9.5 on Windows 2008 R2 64-bit, using default Windows DNS server. Nothing in KB, Plesk support does not respond!! Our whole DNS server is not functional anymore:
dnsmng::update() failed: dnsmng failed: Empty error message from utility.
0: DNSManager.php:727
DNSManager::updateDNSZone(object of type DNSZone, boolean false, boolean false, boolean true)
1: DNSZoneEdit.php:135
DNSZoneEdit->applyChanges()
2: DNSUIPointer.php:28
DNSUIPointer->accessItem(string 'POST', NULL null)
3: UIPointer.php:601
4: plesk.php:43
*Resolved*
@Michael:
This was resolved in another post, see:
"There is a fix that helps with this dnsmng issue: http://kb.odin.com/en/8652
Might be useful -- we had a case when after applying this fix switching DNS from Bind to MS kept hanging when run from Plesk panel or from command line. It was caused by hung up defpackagemng.exe and dnsmng.exe processes. After killing all instances (can be done from task manager, 'processes' tab, of from command line with 'taskkill /F /IM'), switching nameservers back and forth started to work correctly. "
Make sure to backup your DNS server
I don't have either of those processes running. The only thing I have is dwm.exe and dns.exe.
