Issue domain problems after removal of a site from plesk
nsarantopoulos
after i remove a web site the domain remains on the server and i cannot recreate the domain or the web site with the same domain, how do i remove those domains that they are not needed anymore
than you
sarantopoulos nios
Have you tried to remove it in CLI with the following command:
# plesk bin domain -r domain.com
