Question First Timeout Backupmanager, then a white screen - HELP
SabSchap
VPS Ubuntu 20.04 LTS 64bit
Plesk Obsidian new Version
Hello, I set up backups every minute using a cron job. After I could no longer get to the backup manager by clicking and I got a timeout, I followed the instructions below. After that I got a white screen when trying to access the Plesk dashboard. The site is running. What can I do?
Try to remove this backup task from BackupsScheduled table of Plesk database. Then restart psa service.
I already deleted the cron job when I still had access to the Plesk dashboard. Does this also have to be deleted the way you wrote it? How do I do that?
Have you restarted psa service?
Find and delete record with
1. Login to psa database:
# plesk db
2. Find id of your backup task with
MariaDB [psa]> select * from BackupsScheduled\G
3. Delete this record with:
MariaDB [psa]> delete from BackupsScheduled where id=XXX;
where XXX is id of your backup task.
I have 3 websites. with all full backups on we. on one side, i had set up these minutely backups via cron job. I don't believe that one of the backup tasks that I see here is this cron job. Actually, I had already deleted it.
I followed this instruction after the timeout. After that came the white screen
maybe something is wrong with the files?
Where is a white screen? When you open the Plesk interface if I understand correctly? Are the sites working correctly? What are error messages in logs /var/log/sw-cp-server/error_log and /var/log/sw-cp-server/sw-engine.log ?
yes, the white screen comes up when I open Plesk, want to access the dashboard. So I don't even get the login page. The websites work correctly.
It looks like that Plesk is broken - many missing files and directories. Try to repair it with
# plesk repair installation
I suggest you contact Plesk Support Team. They will check and fix the issue directly on your server.
