Found: A fix for every problem in 9.x
R
rewen125
http://www.interworx.com
Check out the demo.
I've already made the switch. It's been so great, I cannot believe how much support they give and how personal they are. They even take criticism and suggestions nicely and without generic politeness but with genuine respect.
My server has never been better. It took only a few minutes to setup and I've never even done this before. Moving the sites was a breeze. I have more options than ever and they all WORK. Not a single bug so far. I've even integrated RoundCube into their built-in webmail chooser.
I've updated php myself and the backup/restore system is simply amazing compared to Plesk which has never worked. You have to try the demo.
This is my last post here. I just noticed that I had something bookmarked and thought that I should say goodbye and hopefully get some of you to see the light. I could not be happier with InterWorx. I've used cp@nel and plesk.. but neither can compare. The free support alone makes it worth it.
Anyway - farewell everyone.
Hm. Looks like Plesk 3.x ... I guess when they get as advanced as Plesk they will have their own problems ;)
Well as for the maturity of this product, I see they only support up to Fedora Core 4. Now considering this is EOL for so long, they can't even muster up a 5,6,7,8,9 or 10?
Come on, Fedora updates it's versions but please nothing past FC4? At this rate they support FC5 when I am running FC12!
