Issue FTP Connection issue
nuffsaid
Hello Good People
I have a problem with my new Plesk Obsidian Linux server, all FTP connections are failing with the following error
GnuTLS error -110 in gnutls_record_recv: The TLS connection was non-properly terminated.
Here is a log file from the ftp terminal
Code:
Status:    Resolving address of xxx.xxx.xx
Status:    Connecting to xx.xx.xx.xx:21...
Status:    Connection established, waiting for welcome message...
Status:    Initializing TLS...
Status:    Verifying certificate...
Status:    TLS connection established.
Command:    USER jamesbond
Response:    331 Password required for jamesbond
Command:    PASS *****************
Error:    GnuTLS error -110 in gnutls_record_recv: The TLS connection was non-properly terminated.
Status:    Server did not properly shut down TLS connection
Error:    Could not read from socket: ECONNABORTED - Connection aborted
Error:    Could not connect to server
Status:    Waiting to retry...
How can i fix this ?
This issue may be related to corrupted certificate assigned to IP address.
Select another certificate in SSL/TLS certificate at Tools & Settings > IP Addresses > click on IP
