# To have more informations about Proftpd configuration
# look at :
http://www.proftpd.org/
# This is a basic ProFTPD configuration file (rename it to
# 'proftpd.conf' for actual use. It establishes a single server
# and a single anonymous login. It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName "ProFTPD"
#ServerType standalone
ServerType inetd
DefaultServer on
<Global>
DefaultRoot ~ psacln
AllowOverwrite on
</Global>
DefaultTransferMode binary
UseFtpUsers on
TimesGMT off
SetEnv TZ :/etc/localtime
# Port 21 is the standard FTP port.
Port 21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask 022
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances 30
#Following part of this config file were generate by PSA automatically
#Any changes in this part will be overwritten by next manipulation
#with Anonymous FTP feature in PSA control panel.
#Include directive should point to place where FTP Virtual Hosts configurations
#preserved
ScoreboardFile /var/run/proftpd/scoreboard
# Primary log file mest be outside of system logrotate province
TransferLog /usr/local/psa/var/log/xferlog
#Change default group for new files and directories in vhosts dir to psacln
<Directory /var/www/vhosts>
GroupOwner psacln
</Directory>
# Enable PAM authentication
AuthPAM on
AuthPAMConfig proftpd
IdentLookups off
UseReverseDNS off
AuthGroupFile /etc/group
Include /etc/proftpd.include
