Greylisting-Problem / Plesk 10
P
PeWa79
Hi there,
i've got a Problem with QMail. Sometimes when a Contact sends a Message to me the Email comes with a enourmous delay. Here are the logs for one example:
May 24 11:18:05 host309 qmail-queue-handlers[32476]: from=sender@sendedomain
May 24 11:18:05 host309 qmail-queue-handlers[32476]: to=empfänger@empfangsdomain
May 24 11:18:05 host309 greylisting filter[32480]: Starting greylisting filter...
May 24 11:18:05 host309 qmail: 1337851085.249732 new msg 7677102
May 24 11:18:05 host309 qmail: 1337851085.249758 info msg 7677102: bytes 10820 from <[email protected]> qp 32483 uid 2020
May 24 11:18:05 host309 qmail-queue-handlers[32476]: call_handlers: stop call handlers from dir '/opt/psa/handlers/before-queue/global'
May 24 11:25:48 host309 /var/qmail/bin/relaylock[1483]: /var/qmail/bin/relaylock: mail from 207.126.144.133:53713 (eu1sys200aog112.obsmtp.com)
May 24 11:25:49 host309 qmail-queue-handlers[1487]: Handlers Filter before-queue for qmail started ...
May 24 11:25:49 host309 qmail-queue-handlers[1487]: from=sender@sendedomain
May 24 11:25:49 host309 qmail-queue-handlers[1487]: to=empfänger@empfangsdomain
May 24 11:25:49 host309 greylisting filter[1488]: Starting greylisting filter...
May 24 11:25:49 host309 qmail-queue-handlers[1487]: call_handlers: stop call handlers from dir '/opt/psa/handlers/before-queue/global'
May 24 11:47:28 host309 /var/qmail/bin/relaylock[5378]: /var/qmail/bin/relaylock: mail from 207.126.144.147:38168 (eu1sys200aog119.obsmtp.com)
May 24 11:47:29 host309 qmail-queue-handlers[5382]: Handlers Filter before-queue for qmail started ...
May 24 11:47:29 host309 qmail-queue-handlers[5382]: from=sender@sendedomain
May 24 11:47:29 host309 qmail-queue-handlers[5382]: to=empfänger@empfangsdomain
May 24 11:47:29 host309 greylisting filter[5383]: Starting greylisting filter...
May 24 11:47:29 host309 qmail-queue-handlers[5382]: call_handlers: stop call handlers from dir '/opt/psa/handlers/before-queue/global'
May 24 12:13:09 host309 /var/qmail/bin/relaylock[9181]: /var/qmail/bin/relaylock: mail from 207.126.144.117:37639 (eu1sys200aog104.obsmtp.com)
May 24 12:13:09 host309 qmail-queue-handlers[9185]: Handlers Filter before-queue for qmail started ...
May 24 12:13:10 host309 qmail-queue-handlers[9185]: from=sender@sendedomain
May 24 12:13:10 host309 qmail-queue-handlers[9185]: to=empfänger@empfangsdomain
May 24 12:13:10 host309 greylisting filter[9186]: Starting greylisting filter...
May 24 12:13:10 host309 qmail-queue-handlers[9185]: call_handlers: stop call handlers from dir '/opt/psa/handlers/before-queue/global'
May 24 13:16:11 host309 /var/qmail/bin/relaylock[18702]: /var/qmail/bin/relaylock: mail from 207.126.144.117:42087 (eu1sys200aog104.obsmtp.com)
May 24 13:16:12 host309 qmail-queue-handlers[18706]: Handlers Filter before-queue for qmail started ...
May 24 13:16:12 host309 qmail-queue-handlers[18706]: from=sender@sendedomain
May 24 13:16:12 host309 qmail-queue-handlers[18706]: to=empfänger@empfangsdomain
May 24 13:16:12 host309 greylisting filter[18707]: Starting greylisting filter...
May 24 13:16:13 host309 qmail: 1337858173.049607 new msg 7677109
May 24 13:16:13 host309 qmail: 1337858173.049644 info msg 7677109: bytes 32037 from <sender@sendedomain> qp 18710 uid 2020
May 24 13:16:13 host309 qmail: 1337858173.063519 starting delivery 179638: msg 7677109 to local 2-empfänger@empfangsdomain
May 24 13:16:13 host309 qmail: 1337858173.063555 status: local 1/10 remote 0/20
May 24 13:16:13 host309 qmail-local-handlers[18711]: Handlers Filter before-local for qmail started ...
May 24 13:16:13 host309 qmail-local-handlers[18711]: from=sender@sendedomain
May 24 13:16:13 host309 qmail-local-handlers[18711]: to=empfänger@empfangsdomain
May 24 13:16:13 host309 qmail-local-handlers[18711]: mailbox: /var/qmail/mailnames/fink-trans-ver.de/r.zahler
May 24 13:16:13 host309 qmail: 1337858173.069411 delivery 179638: success: did_0+0+2/
May 24 13:16:13 host309 qmail: 1337858173.069541 status: local 0/10 remote 0/20
May 24 13:16:13 host309 qmail: 1337858173.069609 end msg 7677109
May 24 13:31:39 host309 qmail-queue-handlers[20414]: Handlers Filter before-queue for qmail started ...
May 24 13:31:39 host309 qmail-queue-handlers[20414]: from=empfänger@empfangsdomain
May 24 13:31:39 host309 qmail-queue-handlers[20414]: to=sender@sendedomain
May 24 13:31:39 host309 greylisting filter[20415]: Starting greylisting filter...
May 24 13:31:39 host309 qmail: 1337859099.843085 new msg 7677267
May 24 13:31:39 host309 qmail: 1337859099.843109 info msg 7677267: bytes 2419 from <empfänger@empfangsdomain> qp 20416 uid 2020
May 24 13:31:39 host309 qmail: 1337859099.850526 starting delivery 179683: msg 7677267 to remote sender@sendedomain
May 24 13:31:39 host309 qmail: 1337859099.850546 status: local 0/10 remote 1/20
May 24 13:31:39 host309 qmail-remote-handlers[20417]: Handlers Filter before-remote for qmail started ...
May 24 13:31:39 host309 qmail-remote-handlers[20417]: from=empfänger@empfangsdomain
May 24 13:31:39 host309 qmail-remote-handlers[20417]: to=sender@sendedomain
May 24 13:31:40 host309 qmail: 1337859100.811313 delivery 179683: success: 207.126.147.10_accepted_message./Remote_host_said:_250_Thanks/
May 24 13:31:40 host309 qmail: 1337859100.811351 status: local 0/10 remote 0/20
May 24 13:31:40 host309 qmail: 1337859100.811361 end msg 7677267
Why doesn't QMail take the Mail at 11:25 ?
Thanx Peter
I think its a feature of Plesk mail server. The mails will automatically send if the first attempt fails to the sender address. You can see the details from the below kb. Please check are you able to send mails to the sender mail address ?
http://kb.parallels.com/6359
I know how Greylisting works, as you see in the Logfiles the mail has been delivered, but after several attempts.
This can't be right, because after the first deny my emailserver should accept the message from the sender.
So perhaps you can tell me what the Problem of the configuration or the specific situation is?
perhaps you can see in the logfile sth that is not correct.
If I send a mail to the sender it will arrive within short time :-(
I can't tell for sure, but it appears that the email is being sent from different IP addresses in the initial tries (.133, .147) then finally .117 is used. This is why it isn't being accepted at 11:25 as you might initially expect.
