V
VictorBL
Today I tried to upgrade my panel to version 10.1.1 from plesk panel> updates
I have error in the update. The system has sent me two e-mail with details about the error.
Detecting installed product components.
Component plesk/base: mode upgrade, installed=0, available=0
Checking if key update required for component plesk/base
Config allows upgrade from version 10.0 without key update
Currently installed component version is 9.5.2-debian5.0.build95100504.17
Keyupgrade need for plesk/base
Component plesk/psa-autoinstaller: mode up2date, installed=0, available=0
Component plesk/postgresql: mode up2date, installed=0, available=0
Component plesk/pmm: mode upgrade, installed=0, available=0
Component plesk/health-monitor: mode install, installed=0, available=0
Component plesk/pba: mode install, installed=0, available=0
Component plesk/sitebuilder: mode install, installed=0, available=0
Component plesk/billing: mode upgrade, installed=0, available=0
Component plesk/mod-bw: mode upgrade, installed=0, available=0
Component plesk/asp: mode up2date, installed=0, available=0
Component plesk/java: mode upgrade, installed=0, available=0
Component plesk/mod_python: mode up2date, installed=0, available=0
Component plesk/ruby: mode upgrade, installed=0, available=0
Component plesk/cf-support: mode upgrade, installed=0, available=0
Component plesk/miva: mode upgrade, installed=0, available=0
Component plesk/php5: mode upgrade, installed=0, available=0
Component plesk/qmail: mode upgrade, installed=0, available=0
Component plesk/postfix: mode install, installed=0, available=0
Component plesk/psa-firewall: mode upgrade, installed=0, available=0
Component plesk/psa-vpn: mode upgrade, installed=0, available=0
Component plesk/psa-fileserver: mode upgrade, installed=0, available=0
Component plesk/sshterm: mode upgrade, installed=0, available=0
Component plesk/watchdog: mode upgrade, installed=0, available=0
Component plesk/cs-gs: mode upgrade, installed=0, available=0
Component plesk/mailman: mode upgrade, installed=0, available=0
Component plesk/kav: mode upgrade, installed=0, available=0
Component plesk/drweb: mode upgrade, installed=0, available=0
Component plesk/spamassassin: mode upgrade, installed=0, available=0
Component plesk/backup: mode upgrade, installed=0, available=0
Component plesk/atis: mode upgrade, installed=0, available=0
Component plesk/horde: mode upgrade, installed=0, available=0
Component plesk/atmail: mode upgrade, installed=0, available=0
Gathering information about installed license key...
File downloading PSA_10.1.1/plesk_getkeyinfo.sh: 31%..71%..100% was finished.
autoinstaller: Error in execution of /root/psa/PSA_10.1.1/plesk_getkeyinfo.sh
Failed to check whether a new license key is available.
Synchronizing the Debian APT package index files...
Error: Failed to check whether a new license key is available.
Not all packages were installed.
Please, contact product technical support.
And since then I can not access my panel via https: / / myserver: 8443.
I have error: HTTP 500 Internal Server Error.
What I can do?
I can go back to 9.5.2?
Thanks in advance.
What I can do?
Thanks in advance.
