Those of you running Plesk 7.0.3 on Windows and you use Dr. Web that came with Plesk for AV software, you might want to check the DrWebUpW.log file located in the c:\program files\swsoft\plesk\drweb folder on your server.
As of the 19th of January, something changed in the signature that Dr. Web uses when validating users for updates. This caused Dr. Web to cease updating. The log entries will look something like the following:
2005-01-20, 17:00:56 Dr.Web® Update for Windows 95-XP v4.32b
2005-01-20, 17:00:56 Copyright © Igor Daniloff, 1992-2004
2005-01-20, 17:00:56 Invalid URL:
2005-01-20, 17:00:56 Connecting to host: http://update.drweb.com/windows/
2005-01-20, 17:00:56 Searching drweb32.lst...
2005-01-20, 17:00:56 Server error: Access denied
2005-01-20, 17:00:56 Transfer of drweb32.lst failed
2005-01-20, 17:00:56 Cannot download version file
2005-01-20, 17:00:56 Connection interrupted
2005-01-20, 17:00:56 Disconnected
If you have this problem, the fix I came up with is simple. Download this file (I'll be nice and share) - http://www.hgtech.net/patches/drwpatch.zip - extract, and overwrite the existing file (upload.drl) in the c:\program files\swsoft\plesk\drweb directory on your server.
Next, to verify its working and force a download of the latest updates, run drwebupw.exe from the same folder. Click on the big "update now" button to make sure everything is working properly.
I restarted the DrWebCom service from the Plesk Control Panel after I was done, but I don't think it was necessary.
- Matt
- Matt
