I need 2 commands to fix my problem with Plesk 11.5
christiano1203
Basic Pleskian
Hello everybody,
My System: Cent OS 6.5 with Plesk Panel 11.5.3
i need to commands to fix my problem. Maybe somebody can help me.
At the moment all Domains of me use php_handle "apache, mod_php", but i want all Domains have to use "fast_cgi". How is the comand for changing alle Domains to "fast_cgi"?
The next problem is, that all Folder and files are own by "apache". Is there a command to change it to the right person, like system user?
Thank you all for helping....
best regards,
christiano
1.
# for i in `mysql -uadmin -p\`cat /etc/psa/.psa.shadow\` psa -Ns -e "select name from domains"`; do /usr/local/psa/bin/subscription -u $i -php_handler_id fastcgi; done
2.
# plesk bin repair --restore-vhosts-permissions
thank you for your helping.
Can you say me how i how i can use the command # plesk bin repair --restore-vhosts-permissions for an another Directory, because my default directory is not httpdocs, but public_html
When I perfom the command i become errors, because the script say, it can't find httpdocs....
I don't know why you have this strange customization, but looks like that in psa database in hosting table you have www_root field defined as /httpdocs for sites instead of /public_html
Note that this inconsistency can lead to unpredictable consequences.
