I am tried to install plesk and shows the following problem
HTTP Proxy Setup
If you are behind a firewall and use a HTTP proxy, you should specify it here.
If your proxy requires authentication, select "Use Authentication"
and specify the username and password
Current settings:
Do not use proxy.
N) Next page; P) Go back; Q) Cancel installing;
S) Select proxy server; A) Use authentication;
Select action [N]:
Download file versions.inf3:
Curl download failed: Couldn't resolve host 'autoinstall.plesk.com' Can't download http://autoinstall.plesk.com/versions.inf3(press Enter for continue)
i trie
wget http://autoinstall.plesk.com/versions.inf3
--10:00:46-- http://autoinstall.plesk.com/versions.inf3
=> `versions.inf3'
Resolving autoinstall.plesk.com... failed: Temporary failure in name resolution.
And get the same problem.
I have verified the subdominion and it does not respond, the dominion either.
somebody has the same result?
what happens with this?
HTTP Proxy Setup
Current settings:
Do not use proxy.
Select action [N]:
i trie
=> `versions.inf3'
