Is there a Problem with the WordPress Toolkit and WordPress 4.4?
Bob McKay
Hi all,
I've raised another thread on a related matter (it may be the same issue but I don't know so thought I'd raise a seperate thread).
There are known problems with WP-CLI and WordPress 4.4 as described here: http://ryanbenhase.com/fix-problems-with-wp-cli-after-updating-to-wordpres-4-4/
The Plesk WordPress Toolkit using WP-CLI for management of WordPress installations.
So my question is, has anyone else been having lots of problems with WordPress installations recently and does Odin have a response to this?
Bob
Hi Natalya,
Thanks but I'm on Plesk 12 not 12.5 and every single time I have upgraded Plesk to a new major version, it has broken it!
I am also using Customer and Business Manager, I understand Odin has dropped support for this so will it continue to work if I update to Plesk 12.5?
Thanks
Bob
Hi Natalya,
I have now updated my Plesk installation to 12.5 and am still recieving this error for my WordPress installations:
PHP Warning: PHP Startup: Unable to load dynamic library 'C:\Program Files (x86)\Parallels\Plesk\Additional\PleskPHP54\ext\php_pspell.dll' - The specified module could not be found. in Unknown on line 0 PHP Warning: require(/framework/config/migrations.php): failed to open stream: No such file or directory in F:\PLESK\WWW\acme.com\httpdocs\wp-content\themes\Zephyr\framework\functions\helpers.php on line 135 Warning: require(/framework/config/migrations.php): failed to open stream: No such file or directory in F:\PLESK\WWW\acme.com\httpdocs\wp-content\themes\Zephyr\framework\functions\helpers.php on line 135 PHP Warning: require(/framework/config/migrations.php): failed to open stream: No such file or directory in F:\PLESK\WWW\acme.com\httpdocs\wp-content\themes\Zephyr\framework\functions\helpers.php on line 135 Warning: require(/framework/config/migrations.php): failed to open stream: No such file or directory in F:\PLESK\WWW\acme.com\httpdocs\wp-content\themes\Zephyr\framework\functions\helpers.php on line 135 PHP Fatal error: require(): Failed opening required '/framework/config/migrations.php' (include_path='C:\Program Files (x86)\Parallels\Plesk\Additional\wp-cli\vendor/phpunit/phpunit-mock-objects;C:\Program Files (x86)\Parallels\Plesk\Additional\wp-cli\vendor/phpunit/php-token-stream;C:\Program Files (x86)\Parallels\Plesk\Additional\wp-cli\vendor/phpunit/php-code-coverage;C:\Program Files (x86)\Parallels\Plesk\Additional\wp-cli\vendor/phpunit/phpunit;C:\Program Files (x86)\Parallels\Plesk\Additional\wp-cli\vendor/symfony/yaml;.;.\includes;.\pear') in F:\PLESK\WWW\acme.com\httpdocs\wp-content\themes\Zephyr\framework\functions\helpers.php on line 135 Fatal error: require(): Failed opening required '/framework/config/migrations.php' (include_path='C:\Program Files (x86)\Parallels\Plesk\Additional\wp-cli\vendor/phpunit/phpunit-mock-objects;C:\Program Files (x86)\Parallels\Plesk\Additional\wp-cli\vendor/phpunit/php-token-stream;C:\Program Files (x86)\Parallels\Plesk\Additional\wp-cli\vendor/phpunit/php-code-coverage;C:\Program Files (x86)\Parallels\Plesk\Additional\wp-cli\vendor/phpunit/phpunit;C:\Program Files (x86)\Parallels\Plesk\Additional\wp-cli\vendor/symfony/yaml;.;.\includes;.\pear') in F:\PLESK\WWW\acme.com\httpdocs\wp-content\themes\Zephyr\framework\functions\helpers.php on line 135
It appears that the real problems are the fatal errors:
Any advice please!?
Bob
Hello,
We can analyze the issue you faced if you provide us with following log files, which should contain the error messages:
1.Home > Subscriptions > plesk.tld > Websites & Domains > acme.com > error_log
2. %plesk_dir%\admin\logs\php_error.log
Please share with us the details.
