<?xml version="1.0"?>
<execution-result log-location="/usr/local/psa/PMM/sessions/2024-09-10-023242.657/migration.result" local-dump-created="true" export-dump-created="true" local-dump-name="clients/elevelhosting/domains/example.com/backup_info_2409100249.xml" export-dump-name="backup_example.com_2409100249.tar" custom-log-file="/var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/backup.log" status="warnings">
<object type="Subscription" name="example.com">
<object type="Extension" name="Plesk DNSSEC">
<message severity="warning">
<description>Unable to back up extension. Error: Failed to exec backup_restore_helper: Exit code: 3: [2024-09-10 03:56:12.160] 15446:66dfa73c26f9d ERR [panel] Can't open custom log file: /var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/backup.log
PHP Warning: fopen(/var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/profile.log): Failed to open stream: No such file or directory; File: /usr/local/psa/admin/plib/backup/Agent/Profiling/File.php, Line: 26
PHP Warning: fopen(/var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/profile.log): Failed to open stream: No such file or directory in /usr/local/psa/admin/plib/backup/Agent/Profiling/File.php on line 26
[2024-09-10 03:56:13.113] 15446:66dfa73c26f9d ERR [panel] Unable to open the log file '/var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/profile.log', cancel profile logging: Failed to open the profiling log file: fopen(/var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/profile.log): Failed to open stream: No such file or directory
PHP Warning: touch(): Unable to create file /var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/backup.log because No such file or directory; File: /usr/local/psa/admin/plib/Plesk/Log/Writer/File.php, Line: 9
PHP Warning: touch(): Unable to create file /var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/backup.log because No such file or directory in /usr/local/psa/admin/plib/Plesk/Log/Writer/File.php on line 9
PHP Warning: chmod(): No such file or directory; File: /usr/local/psa/admin/plib/Plesk/Log/Writer/File.php, Line: 10
PHP Warning: chmod(): No such file or directory in /usr/local/psa/admin/plib/Plesk/Log/Writer/File.php on line 10
PHP Warning: chown(): No such file or directory; File: /usr/local/psa/admin/plib/Plesk/Log/Writer/File.php, Line: 11
PHP Warning: chown(): No such file or directory in /usr/local/psa/admin/plib/Plesk/Log/Writer/File.php on line 11
"/var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/backup.log" cannot be opened with mode "a"
</description>
</message>
</object>
<object type="Extension" name="SSL It!">
<description>Unable to back up extension. Error: Failed to exec backup_restore_helper: Exit code: 3: [2024-09-10 03:56:13.662] 15468:66dfa73da17f3 ERR [panel] Can't open custom log file: /var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/backup.log
[2024-09-10 03:56:13.704] 15468:66dfa73da17f3 ERR [panel] Unable to open the log file '/var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/profile.log', cancel profile logging: Failed to open the profiling log file: fopen(/var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/profile.log): Failed to open stream: No such file or directory
</description>
</message>
</object>
<object type="Extension" name="Git">
<description>Unable to back up extension. Error: Failed to exec backup_restore_helper: Exit code: 3: [2024-09-10 03:56:13.949] 15478:66dfa73de7a2b ERR [panel] Can't open custom log file: /var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/backup.log
[2024-09-10 03:56:13.991] 15478:66dfa73de7a2b ERR [panel] Unable to open the log file '/var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/profile.log', cancel profile logging: Failed to open the profiling log file: fopen(/var/log/plesk/PMM/backup-2024-09-10-02-32-42-656/profile.log): Failed to open stream: No such file or directory
</description>
</message>
</object>
</object>
</execution-result>
