I've problem with Wordpress when trying to update
Tonism
Hi, I'm using panel version 11.5.30 and my os is CentOS 6.4. I've updated Wordpress and there were some error like this
"Error: Update failed: Non-zero exit status returned by script. Output stream: 'PHP Warning: fread(): Length parameter must be greater than 0 in /usr/local/psa/var/apspackages/apscatalogv6VbNz.zipcc930277-199d-9f/cache/scripts/file-util.php on line 10 PHP Warning: mysql_connect(): Access denied for user 'root'@'localhost' (using password: NO) in /usr/local/psa/var/apspackages/apscatalogv6VbNz.zipcc930277-199d-9f/cache/scripts/db-util.php on line 66 '. Error stream: 'PHP Warning: fread(): Length parameter must be greater than 0 in /usr/local/psa/var/apspackages/apscatalogv6VbNz.zipcc930277-199d-9f/cache/scripts/file-util.php on line 10 PHP Warning: mysql_connect(): Access denied for user 'root'@'localhost' (using password: NO) in /usr/local/psa/var/apspackages/apscatalogv6VbNz.zipcc930277-199d-9f/cache/scripts/db-util.php on line 66 '."
After updated, my site has broken so i've to restore the backup. Any ideas on how to fix this issue? Thank you very much.
