F
Foxtrot@
We have a really bizarre problems with Mailenable & plesk, users from our server cannot email a particular domain that we know to work fine. Here are the error messages:
From Outlook Express
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was '[email protected]'. Subject 'test', Account: '[email protected]', Server: 'mail.domain.tld', Protocol: SMTP, Server Response: '550 Requested action not taken: mailbox unavailable or not local', Port: 25, Secure(SSL): No, Server Error: 550, Error Number: 0x800CCC79
From Webmail
There was an error sending your message: unable to add recipient [[email protected]]: Invalid response code received from server
I've tried :-
- Upgrading to Plesk 7.5.6
- Installing Plesk 7.5.6 for Windows Update (060502.17)
- Running: mchk.exe --all --fix=all, mchk & Plesk Reconfigurator
- Double checking the mail enable SMTP settings.
- The server in question is not on any RBL lists
- Reverse dns is setup correctly.
- The address I'm sending to works fine, I've tested it on other working mail servers.
I can telnet to the domain in question so its not a connection issue, the problem is happening on any of the 300 names on the server so its not a blocking issue, and the server is not listed on any RBL lists. I've also tried sending mails from different IP addresses. If anyone has seen this problem before I'd greatly appreciate any advice you can give.
From Webmail
I've tried :-
