• The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
Mayor upgrade problem
E
EdwardDekker
I have a mayor problem about upgrading Plesk.
My web-installer gets a other (x86_64) arch version than my system normally will run.
Now my installation seems to be broken and I do not getting any further service at my server.
All of my websites are down.
How to correct this to a x86 / i386 arch system.
As I can see the psa-10.3.1-cos5http://autoinstall.plesk.com/PSA_10...e/psa-10.3.1-cos5.build1012110718.16.i386.rpm installation file has to be changed to an i386 arch version.
I fixed the job by
Code:
rpm -e --nodeps psa.x86_64
And
Code:
/usr/local/psa/admin/sbin/autoinstaller --select-product-id plesk  --select-release-id PLESK_10_3_1 --override-os-arch i386  --install-component base
Install all the other updates
Code:
/usr/local/psa/admin/sbin/autoinstaller  --select-product-id plesk --select-release-id PLESK_10_3_1  --override-os-arch i386 --upgrade-installed-components
It looks like that the PSA installer make some fault to select i386 packages at my server.
The PSA web-installer should have a setting like that I want to receive i386 or x64 packages.
Maybe that parallels could create a check-box into the configuration settings of the updater.
