Resolved My https not work every page
Anup Roy
I have a commercial webpage few month ago i convert http to https for better secure, but my every page not work https. Where the problem is anyone can suggest me?Capture.JPG
Hi Anup Roy,
The site is still served over "HTTPS", otherwise you would not see the URL "https://....."
But you sure want to know, why the "SECURE" ( green bar ) is missing at the described page?
Actually, this is very simple:
Mixed content
The site includes HTTP resources.
Reload the page to record requests for HTTP resources.
Code:
Mixed Content: The page at 'https://www.clippingpathoutsource.com/blog/blog.html' was loaded over HTTPS, but requested an insecure image 'http://feeds.wordpress.com/1.0/comments/clippingpathoutsource.wordpress.com/139/'. This content should also be served over HTTPS.
blog.html:223
Mixed Content: The page at 'https://www.clippingpathoutsource.com/blog/blog.html' was loaded over HTTPS, but requested an insecure image 'http://feeds.wordpress.com/1.0/comments/clippingpathoutsource.wordpress.com/126/'. This content should also be served over HTTPS.
blog.html:240
Mixed Content: The page at 'https://www.clippingpathoutsource.com/blog/blog.html' was loaded over HTTPS, but requested an insecure image 'http://feeds.wordpress.com/1.0/comments/clippingpathoutsource.wordpress.com/119/'. This content should also be served over HTTPS.
blog.html:263
Mixed Content: The page at 'https://www.clippingpathoutsource.com/blog/blog.html' was loaded over HTTPS, but requested an insecure image 'http://feeds.wordpress.com/1.0/comments/clippingpathoutsource.wordpress.com/110/'. This content should also be served over HTTPS.
blog.html:284
Mixed Content: The page at 'https://www.clippingpathoutsource.com/blog/blog.html' was loaded over HTTPS, but requested an insecure image 'http://feeds.wordpress.com/1.0/comments/clippingpathoutsource.wordpress.com/98/'. This content should also be served over HTTPS.
blog.html:310
Mixed Content: The page at 'https://www.clippingpathoutsource.com/blog/blog.html' was loaded over HTTPS, but requested an insecure image 'http://feeds.wordpress.com/1.0/comments/clippingpathoutsource.wordpress.com/84/'. This content should also be served over HTTPS.
blog.html:323
Mixed Content: The page at 'https://www.clippingpathoutsource.com/blog/blog.html' was loaded over HTTPS, but requested an insecure image 'http://feeds.wordpress.com/1.0/comments/clippingpathoutsource.wordpress.com/79/'. This content should also be served over HTTPS.
blog.html:339
Mixed Content: The page at 'https://www.clippingpathoutsource.com/blog/blog.html' was loaded over HTTPS, but requested an insecure image 'http://feeds.wordpress.com/1.0/comments/clippingpathoutsource.wordpress.com/76/'. This content should also be served over HTTPS.
blog.html:350
Mixed Content: The page at 'https://www.clippingpathoutsource.com/blog/blog.html' was loaded over HTTPS, but requested an insecure image 'http://feeds.wordpress.com/1.0/comments/clippingpathoutsource.wordpress.com/70/'. This content should also be served over HTTPS.
Yes, I want to see Green bar, I am not clear about your solution, please describe easily in a few words.
Hi Anup Roy,
there is no solution given with my previous post. I just point you to the fact, that you implemented "HTTP" - sources as for example:
Code:
http://feeds.wordpress.com/1.0/comments/clippingpathoutsource.wordpress.com/...
Change the image / feed - URL to "HTTPS" - URLs and you should be fine. ;)
Hi Anup Roy,
Code:
Thanks for your patient.
Some of your sites probably still include resources via http://. This is called mixed content, and most browsers won’t show the lock for pages with mixed content. You will have to make sure your site includes all resources via https:// or protocol-relative URLs (e.g. <script src="//example.com/script.js">).
The error is because some of your contents in the website is using HTTP protocol instead of HTTPS. Update all URLs to https:// will resolve the issue.
