• The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
NEED HELP ! Can't create Domains anymore !?
D
Daniel Hartl
Hello anybody,
i really need help.
Sorry, but my english isn't very good.
I've tried to create a domain on Plesk 9.3.0 (SuSe System)
Before today it even works, but since today I can't create Domains.
If i try, theres this Error-Message:
Failed domain creation: Domaindaten können nicht aktualisiert werden: mailmng failed: mailmng: Unable to remove domain record from locals.
System error 2: No such file or directory
Some errors occured. See log for details
0: DomainPropertiesUIPointer.php:267
DomainPropertiesUIPointer->accessItem_create(string 'POST')
1: DomainPropertiesUIPointer.php:59
DomainPropertiesUIPointer->accessItem(string 'POST', NULL null)
2: UIPointer.php:596
UIPointer->access(string 'POST')
3: plesk.php:38
I don't know how to fix or what happened ?
Hope you can help me really soon, please !!
Sincerly,
Daniel Hartl
If go to Home -> Updates make sure that Horde or Atmail is updated to latest version there.
There's nothing to update.
Plesk and it's components are actual the newest version.
Problem solved
I've written the config again with "/usr/local/psa/admin/sbin/mchk --with-spam".
Now all works.
The problem was, there was no "locals" file in /var/qmail/control.
Now there is one with this text:
localhost
localhost.localdomain
Best regards,
Daniel
