nginx installation problem
jukar
Hello
My server OS is Centos 5.4, and I've installed a Plesk 11.0.9. I've tried to install nginx to improve server response.
I've used update option from plesk panel, but the operation is frozen in "installation started on background"
I've read /tmp/autoinstaller3.log and the last line says:
Descargando el archivo PSA_11.0.9/update-rpm-CentOS-5-x86_64/update-11.0.9-cos5-x86_64.hdr.gz:
Note: Descargando el archivo = Downloading file
But the file update-11.0.9-cos5-x86_64.hdr.gz.tmp is zero bytes length, so the downloading is frozen and updating is not ended.
Any fix?
Thanks
