Question Nginx origin setting for CDN cors problem
yunus çetiner
I'm trying to add a directive on the Plesk panel for nginx, but unfortunately I can't find where to add it. I have a cors problem in fonts with CDN.
Code:
    location ~ \.(ttf|ttc|otf|eot|woff|font.css|css|js|gif|png|jpe?g|svg|svgz|ico|webp)$ {
           add_header Access-Control-Allow-Origin "*";
where should I add this code. I can't find any.
Code:
Hi yunus çetiner,
That goes inside the section "Apache and nginx configuration" in the section "Additional nginx directives".
Or in its absence in the domain file vhost_nginx.conf
i added. after i create cdn. still not work.
[QUOTE = "yunus çetiner, post: 856424, miembro: 187498"] Agregué. después de crear cdn. todavia no funciona
[/CITAR]
Have you tried putting it this way?
add_header "Access-Control-Allow-Origin" "*";[/ QUOTE]
No, I haven't. In fact, this is exactly how I should add the code there.
Code:
Is your code enough?
Code:
add_header 'Access-Control-Allow-Origin' '*';
Code:
Code:
So I see the correct way to put it is with "
