alitalaghat
Hello,
Static files show error 403 after upgrade.
I checked the error log and find this:
31958#0: *100 openat() "/var/www/vhosts/mydomain.com/httpdocs/wp-content/themes/test/style.css" failed (13: Permission denied)
To solve the problem, I must manually change chmod of directories in every parent directory of the file to 755. The default chmod value was 750.
What is the correct solution for solve the issue? Before upgrade it works without any problem with 750 chmod.
Best regards.
Best regards.
