Please Help Me For Chmods !
A
AliD
I'm using plesk 8.6 and creating new domain account..
I want to change chmod main part ... bold and underline section----> /var/www/vhosts/domain.net / top episodes --> httpdocs
because I'm not create new folder this part .. How can ı change this folder chmods :(((
I'm not sure I understand.
As root, you can create a directory under /var/www/vhosts/domain.tld but it won't be accessible via the web. Only files in /var/www/vhosts/domain.tld/httpdocs/ is accessible. PHP scripts can access a directory above this if you need to, however.
The permissions set on /var/www/vhosts/domain.tld should not be changed under normal circumstances because it can potentially create a security issue.
But if you try to explain again, with more details, maybe we can help you achieve what you want.
