Please Help Me ! Plesk IP Deny Problem
AytaçE
I did Plesk IP restriction on the panel. Now you can not log in as admin. command to determine which files to the server, or fix it?
I connected PSA Mysql on the Plesk Panel. And I deleted IP adress date in cp_access table in MYSQL data.
But it didn't working. Do you know how to fix this problem ?
Sincerely,
I solved the problem.
mstsc login to your VPS or Dedicated
command cmd window.
cd %plesk_bin%
dbclient.exe --direct-sql --sql="select * from cp_access"
dbclient.exe --direct-sql --sql="select * from misc where param='access_policy'";
dbclient.exe --direct-sql --sql="update misc set val='allow' where param='access_policy'";
and fixed the problem.
Sincerely,
