Plesk 7.0.2 and ms sql problems
F
fox80129
I've an issue with plesk.
The ms sql database is installed correctly using mixed authentication (windows and sql mode). The login and password are right.If i work directly on the server ms sql works properly,but when i log into plesk and choose the db option in the server section i get this error:
the database is not started or incorrect login and password supplied.
If i go under service management Microsoft sql server is running,and i'm also sure that the login details are correct.
What can i do?
I have a similar problem, I choose mssql database for creation, but get error message, unable to connect to database object. I can see that the database file is created, however if I restart the sqlserver, I also see that, it starts only databases, master, model and tempdb, the database I created with plesk is not started.
