Plesk 9.5.4 + Centos 5 64 bit + qmail-scanner 2.08-5 - SPF problem
G
GinesG
Hi, as stated on Title my problem is with:
Plesk 9.5.4
Centos 5 64 bit
I found this errors at maillog logs:
Jul 25 01:18:03 serverX spf filter[19753]: Error code: (26) DNS lookup failure
Jul 25 01:18:03 serverX spf filter[19753]: Failed to query MAIL-FROM: Temporary DNS failure for 'example.com'.
Jul 25 01:18:03 serverX spf filter[19753]: SPF result: tempfail
Jul 25 01:18:03 serverX qmail-queue-handlers[19752]: handlers_stderr: DEFER
Jul 25 01:18:03 serverX qmail-queue-handlers[19752]: call_handlers: DEFER during call '/usr/local/psa/handlers/info/10-spf-Hl6Rjd/executable' handler
Jul 25 01:18:03 serverX qmail-queue-handlers[19752]: call_handlers: stop call handlers from dir '/usr/local/psa/handlers/before-queue/global'
Jul 25 01:18:03 serverX X-Qmail-Scanner-2.08st: [domainX.net131156746379819742] Unable to open pipe to /var/qmail/bin/qmail-queue.orig [61] (#4.3.0) -
Jul 25 01:18:03 serverX X-Qmail-Scanner-2.08st: [domainX.net131156746379819742] Unable to close pipe to /var/qmail/bin/qmail-queue.orig [61] (#4.3.0) - Illegal seek
Only triggers with this type of spf filter error (DNS lookup failure), rest of mail it's ok.
Queue files at /var/qmail/bin ownership/perms are:
-r-xr-sr-x 1 mhandlers-user popuser 6653 Jul 26 08:33 qmail-queue
-r-xr-sr-x 1 root root 6653 Jul 22 19:57 qmail-queue.backup
-r-s--x--x 1 qmailq qmail 20872 Dec 8 2010 qmail-queue.moved
-rwsr-xr-x 1 qmailq qmail 74344 Dec 8 2010 qmail-queue.orig
-rwsr-xr-x 1 root root 74344 Jul 22 19:57 qmail-queue.orig.backup
Rpm installed are:
qmail-scanner-2.08-5.el5.art
psa-qmail-1.03-cos5.build95101209.08
psa-qmail-rblsmtpd-0.70-cos5.build95101209.08
At panel mail options activated are: SPF, domainkeys and rbmlstp.
I hope somebody found a solution to this before.
Thanks and best regards...
Gines
I forgot tell that without qmail-scanner there is no problem at all.
Regards...
Gines
Could this be the same problem as in this thread?
I am examining the same problem and when I "dig" for the domain I get this error (digging TXT works, though):
~# dig SPF wilson-house.co.uk
; <<>> DiG 9.6-ESV-R4 <<>> SPF wilson-house.co.uk
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 32487
When I query our domain that doesn´t have a SPF entry (but a TXT entry for SPF), the status is NOERROR. So, it seems like a Plesk problem to me.
Lars
