Issue Plesk beam.smp process problem/using much RAM and Sync to Outlook takes long
cloudbridge
Basic Pleskian
Hello Plesk'ians,
Server: VPS 16GB RAM, Debian 9, Plesk Obsidian 18.0.28
Problem: I have a problem with one server that process beam.smp generates many beam.smp processes and uses much ram (PIC htop. Outlook sync mail very long, gmail (plesk account) sync long too.
Solution: After I kill 1 process (PIC2 htop after kill) - other is being killed too, and RAM goes back to normal mode, and everything works, outlook synchronizes mail fast also then.
Question: Why beam.smp so many processes? What causes it to generate and it doesn't stop running, I need to kill it manually. But if i kill one, all is being killed too.
I had this situation about 2-3 days ago, but i didn't kill it, and server was inactive (zombie mode) i was unavailable to connect over ssh etc... it gived me message from KVM that RAM is out of....and this proccess beam.smp was getting all ram at maximum.
Plesk has nothing to do on all of this.
Finally I found the solution. These posts helped to figure this out. RabbitMQ on EC2 Consuming Tons of CPU and How do I restart rabbitmq after switching machines?
What happened was rabbitmq was holding on to all the results that were never freed to the point it became overloaded. I cleared all the stale data in /var/lib/rabbitmq/mnesia/rabbit/, restarted rabbit and it works fine now.
My solution was to disable storing results alltogether with CELERY_IGNORE_RESULT = True in the Celery config file to assure this does not happen again.
Thank you Hextrator, I will try to do some changes with this, because once again before 5mins it started again...
I will let you all know if it will fix it in some days.
