S
SteveDude
I have had an off and on again problem with one Plesk installation running inside Virtuozzo 4. It was working fine and then today, if I login to the control panel remotely, I am only shown the Virtuozzo portions integrated into Plesk. Can't get to the desktop or annything. If I RDP into the server and lauch Plesk from there everything shows fine.
I ran the Plesk Reconfigrator and it found no problems.
This is not the first time this has happened. On other occassions I have had to destroy the container and start all over again. It only happens on container 101.
This last time, I cloned the container from another one, set all the proper addresses and it ran fine for about two weeks.
Any ideas?
Thanks before hand.
Any ideas?
Thanks before hand.
