E
edalb
Hi there
I am trying to install PLESK 8.1.0 On a Debian 3.1 server.
The installation went well till this part.
This is my first time trying Plesk so I would love some help.
Regards
Selecting previously deselected package psa-api.
(Reading database ... 38013 files and directories currently installed.)
Unpacking psa-api (from .../psa-api_8.1.0-debian3.1.build81061226.14_i386.deb) ...
Unpacking psa (from .../psa_8.1.0-debian3.1.build81061129.22_i386.deb) ...
Trying to define super-server internet daemon type... inetd
Trying to check if inetd daemon is running... ERROR: no running inetd found
dpkg: error processing /var/cache/apt/archives/psa_8.1.0-debian3.1.build81061129.22_i386.deb (--unpack):
subprocess pre-installation script returned error exit status 1
Selecting previously deselected package libpam-plesk.
Unpacking libpam-plesk (from .../libpam-plesk_8.1.0-debian3.1.build81061129.22_i386.deb) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
ERROR: Install command execution failed
Errors just before:
- Can't execute package installation command
Regards
