Michael Pöllinger
[Res.] Plesk update from 10 to 11: SQL engine 'intentionally disabled' not supported
Hi community.
This is a reopened thread in Plesk Panel 11 due to original post was openend under Plesk 10.
So sorry for quoting so much.
The fix from Nikolay isn´t applicable
And the manually fix from Cheech doesn´t work for me
Does anyone have the same problem after Updating from Plesk 10 to 11?
kind regards
Michael
Hi community.
Into my messages log do i see this error after a upgrade of Plesk 11.
How could i correct this?Jun 29 11:30:01 serverhost postfix/smtpd[23126]: SQL engine 'intentionally disabled' not supported
Jun 29 11:30:01 serverhost postfix/smtpd[23126]: auxpropfunc error no mechanism available
As the error message suggests there is no real error and it does not affect mail subsystem.
Plesk 11 uses its own SASL auxprop plugin. Previously used 'sql' plugin is not used anymore, but still present in the system. Unfortunately, both 'sql' plugin and libsasl implementation used in Postfix seem to have bugs. The first one doesn't allow configuration in which it will be simply disabled (and will not emit error messages). The second one has two issues. The first problem is that logging level setup for plugins is not working. The second problem is that a number of default plugins (including 'sql') is always loaded, even if they are not listed in configuration. Combination of these problems results in such error messages.
You could try to "fix" your problem by removing 'sql' SASL auxprop plugin from the system. But I, personally, would not, since I'm not sure of possible adverse effects (at least without testing it first).
P.S. You probably should have posted this thread in Plesk 11 forum section.
Hi ,
i had the same issue and i fixed it in this way:
1. Search for smtp.conf: result on my Debian Squeeze System: /usr/lib/sasl2/smtpd.conf and /etc/postfix/sasl/smtpd.conf
2. renamed the /usr/lib/sasl2/smtpd.conf to /usr/lib/sasl2/smtpd.old
3. restart Postfix with /etc/init.d/postfix restart
Now all SQLite error messages are gone and Postfix is still working fine.
Looks like Postfix can only work with one smtp.conf
I tried also to copy the /etc/postfix/sasl/smtpd.conf to /etc/postfix/sasl/smtpd.conf but this was not working.
regards
Cheech
kind regards
Michael
