• Our team is looking to connect with folks who use email services provided by Plesk, or a premium service. If you'd like to be part of the discovery process and share your experiences, we invite you to complete this short screening survey. If your responses match the persona we are looking for, you'll receive a link to schedule a call at your convenience. We look forward to hearing from you!
  • We are looking for U.S.-based freelancer or agency working with SEO or WordPress for a quick 30-min interviews to gather feedback on XOVI, a successful German SEO tool we’re looking to launch in the U.S.
    If you qualify and participate, you’ll receive a $30 Amazon gift card as a thank-you. Please apply here. Thanks for helping shape a better SEO product for agencies!
  • The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
Plesk vhost.conf issue and proxy engine.
brainforge
Basic Pleskian
I have just upgraded by Plesk 9 to Plesk 10 - everything looks fine.
However, I have a subdomain plesk.mydomain.com which is configured using the vhost.conf file for mydomain.com:8443 so that I can get into Plesk from locations where port 8443 is blocked.
This worked find in Plesk 9, but does not work in Plesk 10.
The rewrite commands in vhost.conf file works fine but the proxy commands appear to be ignored.
I just end up at the default Apache test page. Any ideas as to how to correct this.
RewriteEngine on
RewriteCond %{SERVER_PORT} ^80$
RewriteRule $ https://plesk.mydomain.com [R,L]
<Proxy *>
Order deny,allow
Allow from all
</Proxy>
SSLProxyEngine on
ProxyRequests off
ProxyPass / https://localhost:8443/
ProxyPassReverse / https://localhost:8443/
Discovered the problem.
Starting from Plesk 9.5.3 the way vhost*.conf files are handled for subdomains changed.
We had skipped that version and went straight to Plesk 10.
The correct way of doing this for Plesk 10 is as follows:
In .../subdomains/plesk/conf create file: vhost.conf
RewriteEngine on
In .../subdomains/plesk/conf create file: vhost_ssl.conf
SSLProxyEngine on
ProxyRequests off
in addition to that
whenever i tried to uncheck the SSL box for that subdomain, received a segfault terminate for httpd and i had to start it again, after reading some post here, i downloaded websrvmng provide dby igor, since i updated it, httpd no longer crashes after i uncheck/re-check the SSL box, but i still can't get this to work no matter what i go in vhost.conf & vhost_ssl.conf
Please advise...
