Aniello Martuscelli
Username:
TITLE
Problem after Plesk upgrade script
PRODUCT, VERSION, OPERATING SYSTEM, ARCHITECTURE
Plesk 18.0.75
Ubuntu 20.04.06 x86_64
PROBLEM DESCRIPTION
STEPS TO REPRODUCE
Update plesk normally from web update tool
ACTUAL RESULT
Errors in log, but updater after finish, plesk works correctly
EXPECTED RESULT
No error
ANY ADDITIONAL INFORMATION
I had the same problem in upgrading Plesk from the latest 18.0.74 to the latest 18.0.75 on both ubuntu 20.04.06 and newer distros
YOUR EXPECTATIONS FROM PLESK SERVICE TEAM
Help with sorting out
TITLE
Plesk 18.0.75
PROBLEM DESCRIPTION
INFO: Executing upgrade task: 2019-04-25-14-46-58 (forced)
SUCCESS: Upgrade step 2019-04-25-14-46-58_ReportUsage.php was successfully done.
INFO: Executing upgrade task: 2020-03-19-17-13-39 (forced)
SUCCESS: Upgrade step 2020-03-19-17-13-39_UpgradeExtensions.php was successfully done.
ERROR: Upgrade step 2025-11-05-09-56-08_FixGrantPrivileges.php failed with code 1 and output:
INFO: Executing upgrade task: 2025-11-05-09-56-08
[2026-01-16 15:41:30.170] 20155:696a4e1a29925 ERR [panel] SQLSTATE[HY000] [2002] Connection refused:
0: /opt/psa/admin/plib/Upgrade/upgrade.php:46
ERROR: Plesk\Upgrade\Exception: SQLSTATE[HY000] [2002] Connection refused (upgrade.php:46)
Some steps of upgrade failed. Run upgrade with option --repair to rerun failed steps.
Warning: execute post install/upgrade actions
Starting forced Plesk Key upgrade task
**** Package plesk-core scriptlet failed.
***** installation problem report *****
STOP plesk-core-18.0 upgrading AT Fri Jan 16 15:41:30 CET 2026
START plesk-l10n-18.0 installing AT Fri Jan 16 15:41:30 CET 2026
Trying to start service mariadb... active
done
Trying to establish test connection... connected
done
**** Package plesk-l10n scriptlet completed successfully.
STOP plesk-l10n-18.0 installing AT Fri Jan 16 15:41:30 CET 2026
START plesk-backup-utilities-18.0 installing AT Fri Jan 16 15:41:30 CET 2026
**** Package plesk-backup-utilities scriptlet completed successfully.
STOP plesk-backup-utilities-18.0 installing AT Fri Jan 16 15:41:30 CET 2026
**** Product post-install for BASE completed with warnings.
STOP plesk-core-18.0 upgrading AT Fri Jan 16 15:41:30 CET 2026: PROBLEMS FOUND
STOP Bootstrapper 18.0.75 post-install for BASE AT Fri Jan 16 15:41:30 CET 2026
START Bootstrapper 18.0.75 perform-deferred-actions AT Fri Jan 16 15:41:30 CET 2026
**** Product perform-deferred-actions started.
Trying to restart service apache2... active
done
Warning: INFO: [Fri Jan 16 15:41:43 CET 2026]: Service: dovecot, Action: reload-or-restart
Trying to reload-or-restart service dovecot...
***** problem report *****
Warning: reload-or-restart service dovecot failed
/opt/psa/admin/sbin/pleskrc execution failed:
Job for dovecot.service failed because the control process exited with error code.
See "systemctl status dovecot.service" and "journalctl -xe" for details.
Warning : failed to perform deferred action : mail_restore_imap_pop3
SUCCESS: Upgrade step Plesk\Upgrade\Action_UpgradeExtensions was successfully done.
done
**** Product perform-deferred-actions completed successfully.
STOP Bootstrapper 18.0.75 perform-deferred-actions AT Fri Jan 16 15:41:47 CET 2026
START update_history
done
done
**** [update_history] completed successfully.
STOP update_history
STEPS TO REPRODUCE
ACTUAL RESULT
EXPECTED RESULT
No error
