Problem during installation with package...
F
FerranV
I have a problem with a package when installing the panel parallels plesk 9.5 on an x86_64 system.
The machine is running on Virtuozzo. It is a VPS.
Error:
ERROR: Unable to install the "psa-backup-manager-9.5.2-cos5.build95100504.10.x86_64" package.
Not all packages were installed.
Please, contact product technical support.
Thanks,
Did you install Plesk with Virtuozzo template or with autoinstaller inside VPS? Did you tried to find a reason in autoinstaller log /tmp/autoinstall3.log ?
What is the 'log' command? For viewing text files 'less' command should be used. Why you do not use Virtuozzo template for Plesk installation if it is Virtuozzo VPS?
I can not find in the downloads section of parallels. I only see the Windows and I use Linux.
[root@barcelona plesk]# less log/tmp/autoinstall3.log
log/tmp/autoinstall3.log: No such file or directory
Thanks,
[root@barcelona plesk]# less /tmp/autoinstaller3.log
Environment locale name is 'en_US.UTF-8'
Parallels Products Installer 3.6.0 (built on 2010-04-07 15:06 svn rev. 290701) started at (timezone EST) Wed Sep 1 00:48:57 2010
Command line arguments: ./parallels_installer_v3.6.0_build100407.15_os_CentOS_5_x86_64
SourceUrl: original source url is http://autoinstall.plesk.com/
SourceUrl: fixed url is http://autoinstall.plesk.com/
Try to find rcfile...
Autoinstaller rcfile not found.
Checking hostname is sucessfull.
Sources page: source=http://autoinstall.plesk.com/, target_dir=/root/parallels
Proxy page: proxy host is '67.20.50.22', proxy port is 3128
autoinstaller: read output of uname -s with popen
autoinstaller: pclose OK
autoinstaller: read output of uname -m with popen
Virtuozzo envID: 50010
Opsys detected as: os_vendor=CentOS os_name=Linux version=5.5 arch=x86_64 environment=vz
Final opsys (with overriding) is: os_vendor=CentOS os_name=Linux version=5.5 arch=x86_64/tmp/autoinstaller3.log
No any errors here. Errors should be at the end of file.
Final opsys (with overriding) is: os_vendor=CentOS os_name=Linux version=5.5 arch=x86_64 environment=vz
repository: Get brief packages info for all sources
Checking for installed packages...
autoinstaller: read output of rpm -qa --queryformat 'F:system_installed_brief_%{NAME}-%{VERSION}-%{RELEASE}.rpm\nN:%{NAME}\nE:%{EPOCH}\nV:%{VERSION}\nL:%{RELEASE}\nA:%{ARCH}\nf:%{INSTALLTIME}\nB:%{BUILDTIME}\nX:\n'
FileFetcher new object: target_dir=/root/parallels/, main_source_url=http://autoinstall.plesk.com/
Filefetcher: get file (~empty)/products.inf3
File downloading products.inf3: Filefetcher: get file (~empty)/versions.inf3
File downloading versions.inf3: Failed to read product information from the file : Can't process products.inf3: Failed to download the package http://autoinstall.plesk.com/products.inf3:
couldn't connect to host
Can't process versions.inf3: Failed to download the package http://autoinstall.plesk.com/versions.inf3:
