Problem Plesk 11.5.30 (#12) Rotate Backups FTP Remote in Debian
David Abuin Fontan
Since the update panel version 11.5 does not rotate backups to a remote FTP on my servers
Code:
 Error:
Unable to rotate dump: The dump rotation is failed with code '121' at /opt/psa/admin/bin/plesk_agent_manager line 1248.
	main::rotateDump('ftp://[email protected]', '/home/user/Plesk/xxx/completo_1308170317.tar', 1, 'a318774a-3670-41f4-8860-ff2eefea186a', 0, '/opt/psa/PMM/sessions/2013-08-17-031702.221', 1) called at /opt/psa/admin/bin/plesk_agent_manager line 738
	main::__ANON__() called at /usr/share/perl5/Error.pm line 416
	eval {...} called at /usr/share/perl5/Error.pm line 408
	Error::subs::try('CODE(0x255e208)', 'HASH(0x25568a8)') called at /opt/psa/admin/bin/plesk_agent_manager line 745
	main::perform('verbose', 0, 'owner-type', 'server', 'split-size', undef, 'session-path', '/opt/psa/PMM/sessions/2013-08-17-031702.221', 'profile-name', ...) called at /opt/psa/admin/bin/plesk_agent_manager line 1311
	Error::subs::try('CODE(0x1d0fbc0)', 'HASH(0x1d0fef0)') called at /opt/psa/admin/bin/plesk_agent_manager line 1319
	main::main() called at /opt/psa/admin/bin/plesk_agent_manager line 1323.
What I can do? Thanks!
According to the error log you've sent the rotation failed with error 121 that means "Remote I/O error":
# perror 121
OS error code 121: Remote I/O error
I suggest that you review settings of remote FTP server and increase FTP timeout there. Also I recommend that you increase max_execution_time in Plesk PHP configuration file:
grep execution /usr/local/psa/admin/conf/php.ini
max_execution_time = 600
Do not forget restart psa service after changing this value.
I changed the settings and the problem persists...
I use the same settings on all my servers (different paths)
Plesk 11.0.x works fine!
Plesk 11.5.x (#12) error all servers
I see that this error was in previous patches
Code:
11.5.30 Update #5     [12-Jul-2013]
Parallels Plesk Panel 11.5.30 Update #5
    [-] Panel failed to rotate backups on external FTP repository if FTP user was not chrooted.
is it possible that has not been applied to upgrade from plesk 11.0?
Thanks!
The problem is reproducible if no chrooted and you use absolute paths (/home/user/dir_backup/). If you use relative paths (dir_backup/) works fine!
PD: Update #13 does not solve the problem
