Problem recept email with qmail (header split)
B
BMSLTD
I have a problem when I received emails
The headers was split with "\n\n" so part of the header include in the message.
what can I solve this problem ?
thank you of your help
Hello,
I had a similar problem after upgrading.
I checked the Plesk KB and found this: http://kb.odin.com/en/5847.
It actually soleved the problem for me. Hope it works for you.
BTW, this should be made a sticky since I've seen many people looking for a solution to the problem on the forums.
Regards,
BTW make sure you set 'spf check mode' to 'only create received spf headers, never block', as any other option will give outside users (mailing you) a bounce message:
host mail.xxx.com[x.x.x.x] said: 554
mail server permanently rejected message (#5.3.0) (in reply to end of DATA
command)
Hopefully swsoft sees this and fixes this bug too.
