die|webhosterin
Hello,
There are already an issue for the same problem.
I have the problem but only at a single reseller. For all other resellers the problem does not exist.
The Reseller can not assign service packages. The customer is also not applied.
I also have the rights of the reseller checked: Hosting performance settings management.
The rights are set at the reseller.
EDIT: What I now but find strange is that the assignment of the service packages will work again if I rename the Reseller.
Perhaps an important clue. The reseller could no longer assign packets, as he moved to the Power User view and again moved to the provider view. I suspect that this is precisely the problem.
When I again rename the Reseller with the old login, is again the problem.
EDIT: Unfortunately I have been looking forward too early. The problem with the reseller is unfortunately again.
EDIT: The problem is now also at resellers who are re-created.
