Problem with apache Seg faults in OSSEC
Amin Taheri
Golden Pleskian
Plesk Certified Professional
Hey guys,
Im getting this from OSSEC
Received From: www->/var/log/httpd/error_log
Rule: 30104 fired (level 12) -> "Apache segmentation fault."
Portion of the log(s):
[Sat Oct 13 14:05:01 2007] [notice] child pid 2755 exit signal Segmentation fault (11)
So I tried to see if it was in anyones error log
Code:
zgrep -li 'Segmentation fault' /var/www/vhosts/*/statistics/logs/error_log*
Didnt come back with anything. Any other ideas as to how I can find out who crashed the process?
it looks like something died;)
these can be useful for you:
http://kb.swsoft.com/en/260
also try to run stats on failed domain:
# /usr/local/psa/admin/sbin/statistics --calculate-one --domain-name=domain.tld
and check if you receive Seg fault error
problem is you dont know what domain it is, which is the problem to which I was asking the question to in my first post :)
We also have file descriptors set to 131072 on our system so thats not the problem either.
did you read that article?
also, you may try to calc stats for any domain or for all domain with
--all option
check --help for info
We have done the FD already, and IM not sure what calculating stats would do since I doubt it would mention seg faults.
