Forwarded to devs Problem with configuration of php-fpm module
Edward Dekker
Basic Pleskian
TITLE:
PRODUCT, VERSION, OPERATING SYSTEM, ARCHITECTURE:
Product version: Plesk Onyx 17.8.11
Build date: 2018/05/15 14:00
OS version: CentOS 7.5.1804
Revision: c3fb546fb867ac424d65da14d8b023f11ec0d150
Architecture: 64-bit
Wrapper version: 1.2
PHP 5.4.16 (cli) (built: Apr 12 2018 19:02:01)
Copyright (c) 1997-2013 The PHP Group
Zend Engine v2.4.0, Copyright (c) 1998-2013 Zend Technologies with the ionCube PHP Loader (enabled) + Intrusion Protection from ioncube24.com (unconfigured v10.0.3, Copyright (c) 2002-2017, by ionCube Ltd.
PROBLEM DESCRIPTION:
A missing include at the php-fpm module for php5.4 at OS system level by installing Plesk Onyx.
STEPS TO REPRODUCE:
Check php-fpm.service at systemctl and check for failures:
Code:
systemctl | egrep php-fpm.service
If so, locate /etc/php-fpm.conf and add at line 12 of this file:
Code:
include=/etc/php-fpm.d/*.conf.saved_by_psa
FILE:
New code at /etc/php-fpm.conf:
Code:
; FPM Configuration ;
; All relative paths in this configuration file are relative to PHP's install
; prefix.
; Include one or more files. If glob(3) exists, it is used to include a bunch of
; files from a glob(3) pattern. This directive can be used everywhere in the
; file.
; Global Options ;
[global]
; Pid file
; Default Value: none
pid = /run/php-fpm/php-fpm.pid
; Error log file
; Default Value: /var/log/php-fpm.log
error_log = /var/log/php-fpm/error.log
; Log level
; Possible Values: alert, error, warning, notice, debug
; Default Value: notice
;log_level = notice
; If this number of child processes exit with SIGSEGV or SIGBUS within the time
; interval set by emergency_restart_interval then FPM will restart. A value
; of '0' means 'Off'.
; Default Value: 0
;emergency_restart_threshold = 0
; Interval of time used by emergency_restart_interval to determine when
; a graceful restart will be initiated.  This can be useful to work around
; accidental corruptions in an accelerator's shared memory.
; Available Units: s(econds), m(inutes), h(ours), or d(ays)
; Default Unit: seconds
; Default Value: 0
;emergency_restart_interval = 0
; Time limit for child processes to wait for a reaction on signals from master.
; Available units: s(econds), m(inutes), h(ours), or d(ays)
; Default Value: 0
;process_control_timeout = 0
; Send FPM to background. Set to 'no' to keep FPM in foreground for debugging.
; Default Value: yes
daemonize = no
; Pool Definitions ;
; See /etc/php-fpm.d/*.conf
ACTUAL RESULT:
Configuration values will be taken by the correct preferences.
EXPECTED RESULT:
No errors and php-fpm works as it should be.
ANY ADDITIONAL INFORMATION:
YOUR EXPECTATIONS FROM PLESK SERVICE TEAM:
Confirm bug
