my http log showed this:
[Thu May 03 14:32:01 2007] [error] [client 86.4.9.204] mod_security: Access denied with code 500. Pattern match "[[:space:]]+(select|grant|delete|insert|drop|alter|replace|truncate|update|create|rename|describe)[[:space:]]+[A-Z|a-z|0-9|\\*| |\\,]+[[:space:]]+(from|into|table|database|index|view)[[:space:]]+[A-Z|a-z|0-9|\\*| |\\,]" at POST_PAYLOAD [hostname "webmail.telcoworks.co.uk"] [uri "/imp/compose.php?uniq=779qk4cavn8c"]
I tryed webmail even after a dreaded reboot... although the problem still persisted. Then, webmail seems to have started allowing webmail to work again - although no mails are actually being delivered!
They are accepted, as below:
May 3 16:16:13 cms imapd: IMAP connect from @ [127.0.0.1]INFO: LOGIN, user=paul.thomas, ip=[127.0.0.1], protocol=IMAP
May 3 16:16:13 cms relaylock: /var/qmail/bin/relaylock: mail from 127.0.0.1:48172 (localhost)
May 3 16:16:13 cms qmail: 1178205373.255655 new msg 459299
May 3 16:16:13 cms qmail: 1178205373.255784 info msg 459299: bytes 1022 from <
[email protected]> qp 19949 uid 10020
May 3 16:16:13 cms qmail: 1178205373.260411 starting delivery 207: msg 459299 to remote
[email protected]
May 3 16:16:13 cms qmail: 1178205373.260601 status: local 0/10 remote 1/20
May 3 16:16:13 cms qmail-scanner[20612]: Clear:RC:1(127.0.0.1): 0.020093 695
[email protected]in
[email protected] test <
[email protected]> 1178205373.21465-0.cms.psifx.net:2
May 3 16:16:13 cms imapd: 1178205373.334519 LOGOUT, user=paul.thomas, ip=[127.0.0.1], headers=0, body=0, rcvd=677, sent=562, maildir=/var/qmail/mailnames/sending.domain/paul.thomas/Maildir
May 3 16:16:14 cms qmail: 1178205374.509629 delivery 207: success: 65.54.245.104_accepted_message./Remote_host_said:_250__<
[email protected]>_Queued_mail_for_delivery/
May 3 16:16:14 cms qmail: 1178205374.509709 status: local 0/10 remote 0/20
May 3 16:16:14 cms qmail: 1178205374.509731 end msg 459299
If I send to the SAME recipient with POP3 - the mail is delivered instantly!
What gives ?!?
