    CentOS2Alma discussion
  • Inviting everyone to the UX test of a new security feature in the WP Toolkit
    For WordPress site owners, threats posed by hackers are ever-present. Because of this, we are developing a new security feature for the WP Toolkit. If the topic of WordPress website security is relevant to you, we would be grateful if you could share your experience and help us test the usability of this feature. We invite you to join us for a 1-hour online session via Google Meet. Select a convenient meeting time with our friendly UX staff here.
problem with mysql
rout3rx
Basic Pleskian
Hi before and after upgrading to latest version (11.5.0) i have some problem with mysql
now sometimes after login to plesk i get this error :
ERROR: PleskFatalException: Unable to connect to database: mysql_connect(): No such file or directory (auth.php:142)
my.cnf configurarion :
Code:
[mysqld]
local-infile=0
datadir=/var/lib/mysql
socket=/var/lib/mysql/mysql.sock
skip-locking
#skip-innodb
key_buffer = 768M
table_cache = 512
sort_buffer_size = 512K
read_buffer_size = 256K
read_rnd_buffer_size = 1024K
net_buffer_length = 2K
max_allowed_packet = 64M
thread_stack = 256K
query_cache_limit = 1152M
query_cache_size = 128M
query_cache_type = 1
max_connections = 350
max_user_connections=20
interactive_timeout = 70
wait_timeout = 25
connect_timeout = 10
thread_cache_size = 128
max_connect_errors = 10
tmp_table_size = 256M
max_heap_table_size = 128M
innodb_buffer_pool_size = 4G
innodb_log_buffer_size=500K
innodb_thread_concurrency=2
join_buffer_size = 1024
# Try number of CPU's*2 for thread_concurrency
thread_concurrency = 4
myisam_sort_buffer_size = 64M
log-bin
server-id=1
[mysqldump]
quick
[mysql]
no-auto-rehash
#safe-updates
[isamchk]
key_buffer = 8M
sort_buffer_size = 8M
[myisamchk]
key_buffer = 8M
[mysqlhotcopy]
interactive-timeout
[mysqld_safe]
log-error=/var/log/mysqld.log
pid-file=/var/run/mysqld/mysqld.pid
how fix this issue?
thanks
Have you ever tried to restart mysql service with
# /etc/init.d/mysqld stop
# /etc/init.d/mysqld start
and then check errors in log file /var/log/mysqld.log ?
Or check /var/lib/mysql/*.err there is more valuable info of what is the issue with my.cnf
Code:
31230 20:12:01 [Note] /usr/libexec/mysqld: Normal shutdown
131230 20:12:01 [Note] Event Scheduler: Purging the queue. 0 events
131230 20:12:03 [Warning] /usr/libexec/mysqld: Forcing close of thread 17  user: ''
131230 20:12:07  InnoDB: Starting shutdown...
131230 20:12:10  InnoDB: Shutdown completed; log sequence number 28 1652310126
131230 20:12:10 [Note] /usr/libexec/mysqld: Shutdown complete
131230 20:12:10 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
131230 20:12:11 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
131230 20:12:11 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
131230 20:12:11 [Warning] option 'join_buffer_size': unsigned value 1024 adjusted to 8200
131230 20:12:11 [Warning] No argument was provided to --log-bin, and --log-bin-index was not used; so replication may break when this MySQL server acts as a master and has his hostname changed!! Please use '--log-bin=mysqld-bin' to avoid this problem.
131230 20:12:11  InnoDB: Initializing buffer pool, size = 4.0G
131230 20:12:11  InnoDB: Completed initialization of buffer pool
131230 20:12:12  InnoDB: Started; log sequence number 28 1652310126
131230 20:12:12 [Note] Event Scheduler: Loaded 0 events
131230 20:12:12 [Note] /usr/libexec/mysqld: ready for connections.
Version: '5.1.71-log'  socket: '/var/lib/mysql/mysql.sock'  port: 3306  Source distribution
it print's in /var/log/mysqld.log Regularly
Change this line from
#skip-innodb
to
skip-innodb
but then, plesk will tell you, that this is no good idea for an update...
