Problem with Plesk Installer
Janko1000
Regular Pleskian
It is the first time that I have problems with Plesk installer.
Sorry for parts but unfortunately only 10000 characters are allowed.
Fresh Clean Debian 7 minimal:
PS: I have also tested it with Ubuntu 14.
Code:
root@phst1301:~# ./plesk-installer.sh
Welcome to the Parallels Installation and Upgrade Wizard!
This wizard will guide you through the installation or upgrade process. Before
installing or upgrading Parallels products, be sure to back up your data.
To start the installation or upgrade, press N and then press Enter.
To quit the installer, press Q and then press Enter.
------ IMPORTANT ------
* Before installing or upgrading Parallels products, be sure to back up your dat        a.
* New installation of product(s) should be performed on clean servers only.
  Only the operating system with the networking option should be
  installed for new installations.
  Parallels will not be held liable for damages resulting from installation
  of products on a server with anything other than a fresh installation of the
  operating system for which the product installation was intended.
By using this Wizard you agree to the terms and conditions described at
http://www.parallels.com/en/company/terms/ and those of the Parallels Panel End        User
License Agreement.
N) Next page;  Q) Cancel installing
Select an action [N]:
Select product software source
You can install products by using any of the following sources:
* Local media
* Official Parallels server
* Other network site
Current settings:
Install products from Parallels server
Install required system packages from Parallels server
Store downloaded files in: /root/parallels
N) Next page; P) Go back;  Q) Cancel installing
S) Change source; T) Change target directory;
Select an action and press ENTER [N]:
HTTP Proxy Setup
If you are behind a firewall and use an HTTP proxy, you should specify the proxy server below.
If your proxy requires authentication, select "Use authentication"
and specify the username and password
Current settings:
Do not use proxy.
N) Next page; P) Go back;  Q) Cancel installing;
S) Select proxy server; A) Use authentication;
Select the required action [N]:
Checking for installed packages...
File downloading products.inf3: 100% was finished.
File downloading plesk.inf3: 10%..20%..30%..45%..55%..61%..72%..80%..93%..100% was finished.
File downloading ppsmbe.inf3: 100% was finished.
File downloading sitebuilder.inf3: 100% was finished.
File downloading sso.inf3: 100% was finished.
File downloading setemplates.inf3: 100% was finished.
File downloading pp-sitebuilder.inf3: 17%..36%..48%..68%..87%..100% was finished.
File downloading billing.inf3: 14%..30%..40%..56%..72%..91%..100% was finished.
File downloading mysql.inf3: 100% was finished.
File downloading apache.inf3: 100% was finished.
File downloading nginx.inf3: 72%..100% was finished.
Select the desired products and their versions
The following product versions are available:
1. [ ] Parallels Plesk
N) Go to the next page; P) Go to the previous page; Q) Cancel installing
To select a version, type the respective number;
Select an action [N]: 1
1. [*] Parallels Plesk
  2. (*) Parallels Plesk 12.0.18 (Stable)
Would you like to help Parallels make better products by sending information
about installation, upgrade, and other problems? [Yes]: yes
File downloading PSA_12.0.18/plesk-12.0.18-deb7.0-x86_64.inf3: 22%..55%..64%..78%..100% was finished.
File downloading PSA_12.0.18/plesk-patches-12.0.18-deb7.0-x86_64.inf3: 14%..30%..40%..57%..73%..95%..100% was finished.
File downloading SITEBUILDER_12.0.6/sitebuilder-12.0.6-deball-all.inf3: 100% was finished.
File downloading BILLING_12.0.18/billing-12.0.18-deball-all.inf3: 100% was finished.
File downloading NGINX_1.6.0/nginx-1.6.0-deb7.0-x86_64.inf3: 100% was finished.
Registering i386 architecture support
Synchronizing the Debian APT package index files...
Get:1 http://security.debian.org wheezy/updates Release.gpg [836 B]
Get:2 http://ftp.debian.org wheezy Release.gpg [1655 B]
Get:3 http://security.debian.org wheezy/updates Release [102 kB]
Get:4 http://ftp.debian.org wheezy Release [168 kB]
Get:5 http://security.debian.org wheezy/updates/main amd64 Packages [222 kB]
Get:6 http://ftp.debian.org wheezy/main amd64 Packages [5841 kB]
Get:7 http://security.debian.org wheezy/updates/contrib amd64 Packages [14 B]
Get:8 http://security.debian.org wheezy/updates/non-free amd64 Packages [14 B]
Get:9 http://security.debian.org wheezy/updates/main i386 Packages [224 kB]
Ign http://autoinstall.plesk.com wheezy Release.gpg
Get:10 http://security.debian.org wheezy/updates/contrib i386 Packages [14 B]
Get:11 http://security.debian.org wheezy/updates/non-free i386 Packages [14 B]
Get:12 http://security.debian.org wheezy/updates/contrib Translation-en [14 B]
Get:13 http://security.debian.org wheezy/updates/main Translation-en [125 kB]
Get:14 http://security.debian.org wheezy/updates/non-free Translation-en [14 B]
Get:15 http://ftp.debian.org wheezy/contrib amd64 Packages [42.0 kB]
Get:16 http://ftp.debian.org wheezy/non-free amd64 Packages [80.8 kB]
Get:17 http://ftp.debian.org wheezy/main i386 Packages [5858 kB]
Ign http://autoinstall.plesk.com all Release.gpg
Get:18 http://ftp.debian.org wheezy/contrib i386 Packages [42.3 kB]
Get:19 http://ftp.debian.org wheezy/non-free i386 Packages [77.5 kB]
Get:20 http://ftp.debian.org wheezy/contrib Translation-en [34.8 kB]
Get:21 http://ftp.debian.org wheezy/main Translation-en [3846 kB]
Get:22 http://ftp.debian.org wheezy/non-free Translation-en [66.1 kB]
Get:23 http://autoinstall.plesk.com wheezy/all amd64 Packages [33.8 kB]
Get:24 http://autoinstall.plesk.com wheezy/all i386 Packages [34.0 kB]
Get:25 http://autoinstall.plesk.com all/all amd64 Packages [2588 B]
Get:26 http://autoinstall.plesk.com all/all i386 Packages [2588 B]
Get:27 http://autoinstall.plesk.com all/all amd64 Packages [778 B]
Get:28 http://autoinstall.plesk.com all/all i386 Packages [778 B]
Ign http://autoinstall.plesk.com wheezy/all Translation-en
Ign http://autoinstall.plesk.com all/all Translation-en
Fetched 16.8 MB in 12s (1321 kB/s)
Reading package lists...
Detecting installed product components.
Select the installation type for Parallels Plesk
Part2
Code:
Installation types for the product:
1. (*) Typical
       Install typically used components. Recommended for general use.
2. ( ) Without DNS server
       Install typically used components without DNS server (BIND).
3. ( ) Full
       Install all available components.
4. ( ) Custom
       Custom components selection. Recommended only for experienced users.
N) Continue installation with selected type; P) Go the previous page; Q) Cancel installing;
L) View or change components marked for installation;
To select an installation type or choose another product, type the respective number;
Hit http://security.debian.org wheezy/updates Release.gpg
Hit http://ftp.debian.org wheezy Release.gpg
Hit http://security.debian.org wheezy/updates/main amd64 Packages
Hit http://security.debian.org wheezy/updates/contrib amd64 Packages
Hit http://security.debian.org wheezy/updates/non-free amd64 Packages
Hit http://security.debian.org wheezy/updates/main i386 Packages
Hit http://ftp.debian.org wheezy/main amd64 Packages
Hit http://security.debian.org wheezy/updates/contrib i386 Packages
Hit http://security.debian.org wheezy/updates/non-free i386 Packages
Hit http://security.debian.org wheezy/updates/contrib Translation-en
Hit http://ftp.debian.org wheezy/contrib amd64 Packages
Hit http://security.debian.org wheezy/updates/main Translation-en
Hit http://security.debian.org wheezy/updates/non-free Translation-en
Hit http://ftp.debian.org wheezy/non-free amd64 Packages
Hit http://ftp.debian.org wheezy/main i386 Packages
Hit http://ftp.debian.org wheezy/contrib i386 Packages
Hit http://ftp.debian.org wheezy/non-free i386 Packages
Hit http://ftp.debian.org wheezy/contrib Translation-en
Hit http://ftp.debian.org wheezy/main Translation-en
Hit http://ftp.debian.org wheezy/non-free Translation-en
Get:1 http://autoinstall.plesk.com wheezy Release [4990 B]
Ign http://autoinstall.plesk.com wheezy/all amd64 Packages/DiffIndex
Ign http://autoinstall.plesk.com wheezy/all i386 Packages/DiffIndex
Ign http://autoinstall.plesk.com all/all amd64 Packages/DiffIndex
Ign http://autoinstall.plesk.com all/all i386 Packages/DiffIndex
Get:2 http://autoinstall.plesk.com wheezy/all amd64 Packages [779 B]
Get:3 http://autoinstall.plesk.com wheezy/all i386 Packages [769 B]
Hit http://autoinstall.plesk.com wheezy/all amd64 Packages
Hit http://autoinstall.plesk.com wheezy/all i386 Packages
Hit http://autoinstall.plesk.com all/all amd64 Packages
Hit http://autoinstall.plesk.com all/all i386 Packages
Fetched 6538 B in 17s (376 B/s)
Gathering information about installed license key...
Checking whether the package dependencies are resolved.
Determining the amount of free disk space
Following amount of diskpace required in directories:
/opt: 1200.00 Mb.
Total required: 1200.00 Mb, available 153200.00 Mb.
Preparing Your System for Product Installation
There are 247 packages required for the product to function properly, which
were not found in your system.
There are 5 packages that need to be upgraded
in order to install the product.
N) Install packages;
S) Show a list of packages; L) Return to primary components list;
Installing packages
Building dependency tree...
The following extra packages will be installed:
  ca-certificates heirloom-mailx libaio1 libaps libarchive12 libc-client2007e
  libcurl3 libdbd-mysql-perl libdbi-perl libfreetype6 libhtml-template-perl
  libicu48 libjpeg62 libltdl7 libmcrypt4 libmysqlclient18 libnettle4 libodbc1
  libpq5 librtmp0 libssh2-1 libxml2 libxmlrpc-c++4 libxmlrpc-core-c3
  libxslt1.1 mlock mysql-client-5.5 mysql-common mysql-server-5.5
  mysql-server-core-5.5 openssl plesk-librdbmspp plesk-lmlib
  plesk-platform-runtime sgml-base sw-doctrine sw-engine
  sw-libboost-date-time1.54.0 sw-libboost-filesystem1.54.0
  sw-libboost-regex1.54.0 sw-libboost-serialization1.54.0
  sw-libboost-system1.54.0 sw-libboost-thread1.54.0 sw-libpoco xml-core
Suggested packages:
  exim4 mail-transport-agent uw-mailutils libipc-sharedcache-perl
  libmcrypt-dev mcrypt libmyodbc odbc-postgresql tdsodbc unixodbc-bin
  libterm-readkey-perl tinyca sgml-base-doc debhelper
Recommended packages:
  mailx
The following NEW packages will be installed:
  plesk-platform-runtime pp12.0.18-bootstrapper sgml-base sw-doctrine
  sw-engine sw-libboost-date-time1.54.0 sw-libboost-filesystem1.54.0
Part3
Code:
0 upgraded, 46 newly installed, 0 to remove and 18 not upgraded.
Need to get 40.0 MB of archives.
After this operation, 205 MB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
  libaio1 libnettle4 libxml2 libarchive12 librtmp0 libssh2-1 libcurl3
  libfreetype6 libicu48 libjpeg62 libltdl7 mysql-common libmysqlclient18
  libodbc1 libxslt1.1 libdbi-perl libdbd-mysql-perl mysql-client-5.5
  mysql-server-core-5.5 mysql-server-5.5 sgml-base openssl ca-certificates
  heirloom-mailx mlock libc-client2007e libhtml-template-perl libmcrypt4
  libpq5 libxmlrpc-core-c3 libxmlrpc-c++4 xml-core plesk-platform-runtime
  plesk-librdbmspp sw-libboost-date-time1.54.0 sw-libboost-system1.54.0
  sw-libboost-filesystem1.54.0 sw-libboost-regex1.54.0
  sw-libboost-serialization1.54.0 sw-libboost-thread1.54.0 sw-libpoco libaps
  plesk-lmlib sw-doctrine sw-engine pp12.0.18-bootstrapper
Authentication warning overridden.
Get:1 http://security.debian.org/ wheezy/updates/main libxml2 amd64 2.8.0+dfsg1-7+wheezy2 [904 kB]
Get:2 http://ftp.debian.org/debian/ wheezy/main libaio1 amd64 0.3.109-3 [9150 B]
Get:3 http://ftp.debian.org/debian/ wheezy/main libnettle4 amd64 2.4-3 [149 kB]
Get:4 http://autoinstall.plesk.com/debian/PSA_12.0.18/ wheezy/all plesk-platform-runtime amd64 1.0-892097.14062518 [19.9 kB]
Get:5 http://security.debian.org/ wheezy/updates/main libcurl3 amd64 7.26.0-1+wheezy11 [331 kB]
Get:6 http://security.debian.org/ wheezy/updates/main mysql-common all 5.5.40-0+wheezy1 [75.5 kB]
Get:7 http://security.debian.org/ wheezy/updates/main libmysqlclient18 amd64 5.5.40-0+wheezy1 [678 kB]
Get:8 http://ftp.debian.org/debian/ wheezy/main libarchive12 amd64 3.0.4-3+nmu1 [304 kB]
Get:9 http://autoinstall.plesk.com/debian/PSA_12.0.18/ wheezy/all plesk-librdbmspp amd64 2.0-735641.14062518 [240 kB]
Get:10 http://security.debian.org/ wheezy/updates/main mysql-client-5.5 amd64 5.5.40-0+wheezy1 [1890 kB]
Get:11 http://ftp.debian.org/debian/ wheezy/main librtmp0 amd64 2.4+20111222.git4e06e21-1 [62.3 kB]
Get:12 http://ftp.debian.org/debian/ wheezy/main libssh2-1 amd64 1.4.2-1.1 [133 kB]
Get:13 http://security.debian.org/ wheezy/updates/main mysql-server-core-5.5 amd64 5.5.40-0+wheezy1 [3401 kB]
Get:14 http://ftp.debian.org/debian/ wheezy/main libfreetype6 amd64 2.4.9-1.1 [451 kB]
Get:15 http://autoinstall.plesk.com/debian/PSA_12.0.18/ wheezy/all sw-libboost-date-time1.54.0 amd64 1.54.0-14020414 [19.3 kB]
Get:16 http://ftp.debian.org/debian/ wheezy/main libicu48 amd64 4.8.1.1-12+deb7u1 [4742 kB]
Get:17 http://security.debian.org/ wheezy/updates/main mysql-server-5.5 amd64 5.5.40-0+wheezy1 [2093 kB]
Get:18 http://security.debian.org/ wheezy/updates/main openssl amd64 1.0.1e-2+deb7u13 [701 kB]
Get:19 http://autoinstall.plesk.com/debian/PSA_12.0.18/ wheezy/all sw-libboost-system1.54.0 amd64 1.54.0-14020414 [5650 B]
Get:20 http://ftp.debian.org/debian/ wheezy/main libjpeg62 amd64 6b1-3+deb7u1 [96.9 kB]
Get:21 http://ftp.debian.org/debian/ wheezy/main libltdl7 amd64 2.4.2-1.1 [352 kB]
Get:22 http://autoinstall.plesk.com/debian/PSA_12.0.18/ wheezy/all sw-libboost-filesystem1.54.0 amd64 1.54.0-14020414 [37.8 kB]
Get:23 http://ftp.debian.org/debian/ wheezy/main libodbc1 amd64 2.2.14p2-5 [252 kB]
Get:24 http://ftp.debian.org/debian/ wheezy/main libxslt1.1 amd64 1.1.26-14.1 [254 kB]
Get:25 http://autoinstall.plesk.com/debian/PSA_12.0.18/ wheezy/all sw-libboost-regex1.54.0 amd64 1.54.0-14020414 [400 kB]
Get:26 http://ftp.debian.org/debian/ wheezy/main libdbi-perl amd64 1.622-1+deb7u1 [892 kB]
Get:27 http://ftp.debian.org/debian/ wheezy/main libdbd-mysql-perl amd64 4.021-1+b1 [126 kB]
Get:28 http://ftp.debian.org/debian/ wheezy/main sgml-base all 1.26+nmu4 [14.6 kB]
Get:29 http://ftp.debian.org/debian/ wheezy/main ca-certificates all 20130119+deb7u1 [210 kB]
Get:30 http://autoinstall.plesk.com/debian/PSA_12.0.18/ wheezy/all sw-libboost-serialization1.54.0 amd64 1.54.0-14020414 [185 kB]
Get:31 http://ftp.debian.org/debian/ wheezy/main heirloom-mailx amd64 12.5-2 [274 kB]
Get:32 http://ftp.debian.org/debian/ wheezy/main mlock amd64 8:2007f~dfsg-2 [34.0 kB]
Get:33 http://autoinstall.plesk.com/debian/PSA_12.0.18/ wheezy/all sw-libboost-thread1.54.0 amd64 1.54.0-14020414 [33.3 kB]
Get:34 http://ftp.debian.org/debian/ wheezy/main libc-client2007e amd64 8:2007f~dfsg-2 [758 kB]
Get:35 http://ftp.debian.org/debian/ wheezy/main libhtml-template-perl all 2.91-1 [72.0 kB]
Get:36 http://ftp.debian.org/debian/ wheezy/main libmcrypt4 amd64 2.5.8-3.1 [83.2 kB]
Get:37 http://autoinstall.plesk.com/debian/PSA_12.0.18/ wheezy/all sw-libpoco amd64 1.4.3p1-14062518 [2329 kB]
Get:38 http://ftp.debian.org/debian/ wheezy/main libpq5 amd64 9.1.14-0+deb7u1 [137 kB]
Get:39 http://ftp.debian.org/debian/ wheezy/main libxmlrpc-core-c3 amd64 1.16.33-3.2 [186 kB]
Get:40 http://ftp.debian.org/debian/ wheezy/main libxmlrpc-c++4 amd64 1.16.33-3.2 [153 kB]
Get:41 http://ftp.debian.org/debian/ wheezy/main xml-core all 0.13+nmu2 [24.2 kB]
Get:42 http://autoinstall.plesk.com/debian/PSA_12.0.18/ wheezy/all libaps amd64 1.0.7-798670.14062518 [2634 kB]
Get:43 http://autoinstall.plesk.com/debian/PSA_12.0.18/ wheezy/all plesk-lmlib amd64 0.0.6-591.14062719 [583 kB]
Get:44 http://autoinstall.plesk.com/debian/PSA_12.0.18/ wheezy/all sw-doctrine all 1.0.4-0.280352 [361 kB]
Get:45 http://autoinstall.plesk.com/debian/PSA_12.0.18/ wheezy/all sw-engine amd64 2.13.11-debian70.201407011527 [13.1 MB]
Get:46 http://autoinstall.plesk.com/debian/PSA_12.0.18/ wheezy/all pp12.0.18-bootstrapper amd64 12.0.18-debian7.0.build1200140821.14 [165 kB]
debconf: delaying package configuration, since apt-utils is not installed
Part4
Code:
Fetched 40.0 MB in 1s (22.1 MB/s)
Selecting previously unselected package libaio1:amd64.
(Reading database ... 13022 files and directories currently installed.)
Unpacking libaio1:amd64 (from .../libaio1_0.3.109-3_amd64.deb) ...
Selecting previously unselected package libnettle4:amd64.
Unpacking libnettle4:amd64 (from .../libnettle4_2.4-3_amd64.deb) ...
Selecting previously unselected package libxml2:amd64.
Unpacking libxml2:amd64 (from .../libxml2_2.8.0+dfsg1-7+wheezy2_amd64.deb) ...
Selecting previously unselected package libarchive12:amd64.
Unpacking libarchive12:amd64 (from .../libarchive12_3.0.4-3+nmu1_amd64.deb) ...
Selecting previously unselected package librtmp0:amd64.
Unpacking librtmp0:amd64 (from .../librtmp0_2.4+20111222.git4e06e21-1_amd64.deb) ...
Selecting previously unselected package libssh2-1:amd64.
Unpacking libssh2-1:amd64 (from .../libssh2-1_1.4.2-1.1_amd64.deb) ...
Selecting previously unselected package libcurl3:amd64.
Unpacking libcurl3:amd64 (from .../libcurl3_7.26.0-1+wheezy11_amd64.deb) ...
Selecting previously unselected package libfreetype6:amd64.
Unpacking libfreetype6:amd64 (from .../libfreetype6_2.4.9-1.1_amd64.deb) ...
Selecting previously unselected package libicu48:amd64.
Unpacking libicu48:amd64 (from .../libicu48_4.8.1.1-12+deb7u1_amd64.deb) ...
Selecting previously unselected package libjpeg62:amd64.
Unpacking libjpeg62:amd64 (from .../libjpeg62_6b1-3+deb7u1_amd64.deb) ...
Selecting previously unselected package libltdl7:amd64.
Unpacking libltdl7:amd64 (from .../libltdl7_2.4.2-1.1_amd64.deb) ...
Selecting previously unselected package mysql-common.
Unpacking mysql-common (from .../mysql-common_5.5.40-0+wheezy1_all.deb) ...
Selecting previously unselected package libmysqlclient18:amd64.
Unpacking libmysqlclient18:amd64 (from .../libmysqlclient18_5.5.40-0+wheezy1_amd64.deb) ...
Selecting previously unselected package libodbc1:amd64.
Unpacking libodbc1:amd64 (from .../libodbc1_2.2.14p2-5_amd64.deb) ...
Selecting previously unselected package libxslt1.1:amd64.
Unpacking libxslt1.1:amd64 (from .../libxslt1.1_1.1.26-14.1_amd64.deb) ...
Selecting previously unselected package libdbi-perl.
Unpacking libdbi-perl (from .../libdbi-perl_1.622-1+deb7u1_amd64.deb) ...
Selecting previously unselected package libdbd-mysql-perl.
Unpacking libdbd-mysql-perl (from .../libdbd-mysql-perl_4.021-1+b1_amd64.deb) ...
Selecting previously unselected package mysql-client-5.5.
Unpacking mysql-client-5.5 (from .../mysql-client-5.5_5.5.40-0+wheezy1_amd64.deb) ...
Selecting previously unselected package mysql-server-core-5.5.
Unpacking mysql-server-core-5.5 (from .../mysql-server-core-5.5_5.5.40-0+wheezy1_amd64.deb) ...
Setting up mysql-common (5.5.40-0+wheezy1) ...
Selecting previously unselected package mysql-server-5.5.
(Reading database ... 13521 files and directories currently installed.)
Unpacking mysql-server-5.5 (from .../mysql-server-5.5_5.5.40-0+wheezy1_amd64.deb) ...
Selecting previously unselected package sgml-base.
Unpacking sgml-base (from .../sgml-base_1.26+nmu4_all.deb) ...
Selecting previously unselected package openssl.
Unpacking openssl (from .../openssl_1.0.1e-2+deb7u13_amd64.deb) ...
Selecting previously unselected package ca-certificates.
Unpacking ca-certificates (from .../ca-certificates_20130119+deb7u1_all.deb) ...
Selecting previously unselected package heirloom-mailx.
Unpacking heirloom-mailx (from .../heirloom-mailx_12.5-2_amd64.deb) ...
Selecting previously unselected package mlock.
Unpacking mlock (from .../mlock_8%3a2007f~dfsg-2_amd64.deb) ...
Selecting previously unselected package libc-client2007e.
Unpacking libc-client2007e (from .../libc-client2007e_8%3a2007f~dfsg-2_amd64.deb) ...
Selecting previously unselected package libhtml-template-perl.
Unpacking libhtml-template-perl (from .../libhtml-template-perl_2.91-1_all.deb) ...
Selecting previously unselected package libmcrypt4.
Unpacking libmcrypt4 (from .../libmcrypt4_2.5.8-3.1_amd64.deb) ...
Selecting previously unselected package libpq5.
Unpacking libpq5 (from .../libpq5_9.1.14-0+deb7u1_amd64.deb) ...
Selecting previously unselected package libxmlrpc-core-c3.
Unpacking libxmlrpc-core-c3 (from .../libxmlrpc-core-c3_1.16.33-3.2_amd64.deb) ...
Selecting previously unselected package libxmlrpc-c++4.
Unpacking libxmlrpc-c++4 (from .../libxmlrpc-c++4_1.16.33-3.2_amd64.deb) ...
Selecting previously unselected package xml-core.
Unpacking xml-core (from .../xml-core_0.13+nmu2_all.deb) ...
Selecting previously unselected package plesk-platform-runtime.
Unpacking plesk-platform-runtime (from .../plesk-platform-runtime_1.0-892097.14062518_amd64.deb) ...
Selecting previously unselected package plesk-librdbmspp.
Unpacking plesk-librdbmspp (from .../plesk-librdbmspp_2.0-735641.14062518_amd64.deb) ...
Selecting previously unselected package sw-libboost-date-time1.54.0.
Unpacking sw-libboost-date-time1.54.0 (from .../sw-libboost-date-time1.54.0_1.54.0-14020414_amd64.deb) ...
Selecting previously unselected package sw-libboost-system1.54.0.
Unpacking sw-libboost-system1.54.0 (from .../sw-libboost-system1.54.0_1.54.0-14020414_amd64.deb) ...
Selecting previously unselected package sw-libboost-filesystem1.54.0.
Unpacking sw-libboost-filesystem1.54.0 (from .../sw-libboost-filesystem1.54.0_1.54.0-14020414_amd64.deb) ...
Selecting previously unselected package sw-libboost-regex1.54.0.
Unpacking sw-libboost-regex1.54.0 (from .../sw-libboost-regex1.54.0_1.54.0-14020414_amd64.deb) ...
Selecting previously unselected package sw-libboost-serialization1.54.0.
Unpacking sw-libboost-serialization1.54.0 (from .../sw-libboost-serialization1.54.0_1.54.0-14020414_amd64.deb) ...
Selecting previously unselected package sw-libboost-thread1.54.0.
Unpacking sw-libboost-thread1.54.0 (from .../sw-libboost-thread1.54.0_1.54.0-14020414_amd64.deb) ...
Selecting previously unselected package sw-libpoco.
Unpacking sw-libpoco (from .../sw-libpoco_1.4.3p1-14062518_amd64.deb) ...
Selecting previously unselected package libaps.
Unpacking libaps (from .../libaps_1.0.7-798670.14062518_amd64.deb) ...
Selecting previously unselected package plesk-lmlib.
Part5
Code:
Unpacking plesk-lmlib (from .../plesk-lmlib_0.0.6-591.14062719_amd64.deb) ...
Selecting previously unselected package sw-doctrine.
Unpacking sw-doctrine (from .../sw-doctrine_1.0.4-0.280352_all.deb) ...
Selecting previously unselected package sw-engine.
Unpacking sw-engine (from .../sw-engine_2.13.11-debian70.201407011527_amd64.deb) ...
Selecting previously unselected package pp12.0.18-bootstrapper.
Unpacking pp12.0.18-bootstrapper (from .../pp12.0.18-bootstrapper_12.0.18-debian7.0.build1200140821.14_amd64.deb) ...
Setting up libaio1:amd64 (0.3.109-3) ...
Setting up libnettle4:amd64 (2.4-3) ...
Setting up libxml2:amd64 (2.8.0+dfsg1-7+wheezy2) ...
Setting up libarchive12:amd64 (3.0.4-3+nmu1) ...
Setting up librtmp0:amd64 (2.4+20111222.git4e06e21-1) ...
Setting up libssh2-1:amd64 (1.4.2-1.1) ...
Setting up libcurl3:amd64 (7.26.0-1+wheezy11) ...
Setting up libfreetype6:amd64 (2.4.9-1.1) ...
Setting up libicu48:amd64 (4.8.1.1-12+deb7u1) ...
Setting up libjpeg62:amd64 (6b1-3+deb7u1) ...
Setting up libltdl7:amd64 (2.4.2-1.1) ...
Setting up libmysqlclient18:amd64 (5.5.40-0+wheezy1) ...
Setting up libodbc1:amd64 (2.2.14p2-5) ...
Setting up libxslt1.1:amd64 (1.1.26-14.1) ...
Setting up libdbi-perl (1.622-1+deb7u1) ...
Setting up libdbd-mysql-perl (4.021-1+b1) ...
Setting up mysql-client-5.5 (5.5.40-0+wheezy1) ...
Setting up mysql-server-core-5.5 (5.5.40-0+wheezy1) ...
Setting up mysql-server-5.5 (5.5.40-0+wheezy1) ...
Stopping MySQL database server: mysqld.
/var/lib/dpkg/info/mysql-server-5.5.postinst: line 146: logger: command not found
ATTENTION: An error has occured. More info is in the syslog!
/var/lib/dpkg/info/mysql-server-5.5.postinst: line 236: logger: command not found
dpkg: error processing mysql-server-5.5 (--configure):
subprocess installed post-installation script returned error exit status 127
Setting up sgml-base (1.26+nmu4) ...
Setting up openssl (1.0.1e-2+deb7u13) ...
Setting up ca-certificates (20130119+deb7u1) ...
Setting up heirloom-mailx (12.5-2) ...
update-alternatives: using /usr/bin/heirloom-mailx to provide /usr/bin/mailx (mailx) in auto mode
Setting up mlock (8:2007f~dfsg-2) ...
Setting up libc-client2007e (8:2007f~dfsg-2) ...
Setting up libhtml-template-perl (2.91-1) ...
Setting up libmcrypt4 (2.5.8-3.1) ...
Setting up libpq5 (9.1.14-0+deb7u1) ...
Setting up libxmlrpc-core-c3 (1.16.33-3.2) ...
Setting up libxmlrpc-c++4 (1.16.33-3.2) ...
Setting up xml-core (0.13+nmu2) ...
Setting up plesk-platform-runtime (1.0-892097.14062518) ...
Setting up plesk-librdbmspp (2.0-735641.14062518) ...
Setting up sw-libboost-date-time1.54.0 (1.54.0-14020414) ...
Setting up sw-libboost-system1.54.0 (1.54.0-14020414) ...
Setting up sw-libboost-filesystem1.54.0 (1.54.0-14020414) ...
Setting up sw-libboost-regex1.54.0 (1.54.0-14020414) ...
Setting up sw-libboost-serialization1.54.0 (1.54.0-14020414) ...
Setting up sw-libboost-thread1.54.0 (1.54.0-14020414) ...
Setting up sw-libpoco (1.4.3p1-14062518) ...
Setting up libaps (1.0.7-798670.14062518) ...
Setting up plesk-lmlib (0.0.6-591.14062719) ...
Setting up sw-doctrine (1.0.4-0.280352) ...
Setting up sw-engine (2.13.11-debian70.201407011527) ...
Adding system startup for /etc/init.d/sw-engine ...
   /etc/rc0.d/K20sw-engine -> ../init.d/sw-engine
   /etc/rc1.d/K20sw-engine -> ../init.d/sw-engine
   /etc/rc6.d/K20sw-engine -> ../init.d/sw-engine
   /etc/rc2.d/S20sw-engine -> ../init.d/sw-engine
   /etc/rc3.d/S20sw-engine -> ../init.d/sw-engine
   /etc/rc4.d/S20sw-engine -> ../init.d/sw-engine
   /etc/rc5.d/S20sw-engine -> ../init.d/sw-engine
dpkg: dependency problems prevent configuration of pp12.0.18-bootstrapper:
pp12.0.18-bootstrapper depends on virtual-mysql-server | mysql-server; however:
  Package virtual-mysql-server is not installed.
  Package mysql-server-5.5 which provides virtual-mysql-server is not configured yet.
  Package mysql-server is not installed.
Processing triggers for ca-certificates ...
dpkg: error processing pp12.0.18-bootstrapper (--configure):
dependency problems - leaving unconfigured
Updating certificates in /etc/ssl/certs... 171 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d....done.
Processing triggers for sgml-base ...
Errors were encountered while processing:
mysql-server-5.5
E: Sub-process /usr/bin/dpkg returned an error code (1)
ERROR: An error occurred on attempt to install packages.
Attention! Your software might be inoperable.
Please, contact product technical support.
root@phst1301:~#
