FranciscoWeb19
Hello all, first time here.
I have this problem in a server where I tried to install a SSL certificate x.509.
I have set some config options in httpd.conf to install that certificate and restarted apache, quite ok until this point.
When I check via SSChecker I see that the real certificate for the appropriate domain (I have lots of domains hosted in this server) is under the plesk certificate, as a chain certificate.
The question is, how can I fix this not messing up with the Plesk Panel I use (via https)?
Check it out the result here: http://www.sslshopper.com/ssl-checker.html#hostname=www.armazemdasaliancas.com.br
Can I remove the default certificate in Plesk Administration without causing any trouble to my Plesk Panel?
Any help will be appreciated.
Thanks in advance.
Thanks in advance.
