Problem with SMTP
NamNam
Basic Pleskian
I read lot of topics concerning this problem.
I can send mail from webmail, but if i try to use any client mail, i can receive but not send.
I try to activated 587 on all ips, nothing.
Can you help me ?
My Main.cf :
smtpd_relay_restrictions = permit_mynetworks permit_sasl_authenticated defer_unauth_destination
myhostname = 01.serveur-mca.pro
alias_maps = hash:/etc/aliases, hash:/var/spool/postfix/plesk/aliases
alias_database = hash:/etc/aliases
myorigin = /etc/mailname
mydestination = localhost.ip-149-202-199.eu, localhost, localhost.localdomain
relayhost =
mynetworks =
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
inet_protocols = all
virtual_mailbox_domains = $virtual_mailbox_maps, hash:/var/spool/postfix/plesk/virtual_domains
virtual_alias_maps = $virtual_maps, hash:/var/spool/postfix/plesk/virtual
virtual_mailbox_maps = , hash:/var/spool/postfix/plesk/vmailbox
transport_maps = , hash:/var/spool/postfix/plesk/transport
smtpd_tls_security_level = may
smtp_tls_security_level = may
smtp_use_tls = no
smtpd_timeout = 3600s
smtpd_proxy_timeout = 3600s
disable_vrfy_command = yes
smtpd_sender_restrictions = check_sender_access hash:/var/spool/postfix/plesk/blacklists, permit_sasl_authenticated
smtpd_client_restrictions = permit_mynetworks, permit_sasl_authenticated
smtp_send_xforward_command = yes
smtpd_authorized_xforward_hosts = 127.0.0.0/8 [::1]/128
smtpd_sasl_auth_enable = yes
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination
virtual_mailbox_base = /var/qmail/mailnames
virtual_uid_maps = static:30
virtual_gid_maps = static:31
smtpd_milters = , inet:127.0.0.1:12768
sender_dependent_default_transport_maps = hash:/var/spool/postfix/plesk/sdd_transport_maps
virtual_transport = plesk_virtual
plesk_virtual_destination_recipient_limit = 1
mailman_destination_recipient_limit = 1
virtual_mailbox_limit = 0
smtpd_tls_mandatory_protocols = !SSLv2,!SSLv3
smtpd_tls_protocols = SSLv3, TLSv1
smtpd_tls_ciphers = medium
smtpd_tls_mandatory_ciphers = medium
tls_medium_cipherlist = HIGH:!aNULL:!MD5
smtpd_tls_exclude_ciphers = aNULL
smtpd_sasl_security_options = noplaintext
smtpd_tls_auth_only = yes
tls_ssl_options = NO_COMPRESSION
message_size_limit = 10240000
My Master.cf
smtp inet n - - - - smtpd
#smtp inet n - - - 1 postscreen
#smtpd pass - - - - - smtpd
#dnsblog unix - - - - 0 dnsblog
#tlsproxy unix - - - - 0 tlsproxy
#submission inet n - - - - smtpd
# -o syslog_name=postfix/submission
# -o smtpd_tls_security_level=may
# -o smtpd_sasl_auth_enable=yes
# -o smtpd_reject_unlisted_recipient=no
# -o smtpd_client_restrictions=$mua_client_restrictions
# -o smtpd_helo_restrictions=$mua_helo_restrictions
# -o smtpd_sender_restrictions=$mua_sender_restrictions
# -o smtpd_recipient_restrictions=
# -o smtpd_relay_restrictions=permit_sasl_authenticated,reject
# -o milter_macro_daemon_name=ORIGINATING
#smtps inet n - - - - smtpd
# -o syslog_name=postfix/smtps
# -o smtpd_tls_wrappermode=yes
#628 inet n - - - - qmqpd
cleanup unix n - - - 0 cleanup
#qmgr unix n - n 300 1 oqmgr
tlsmgr unix - - - 1000? 1 tlsmgr
rewrite unix - - - - - trivial-rewrite
bounce unix - - - - 0 bounce
defer unix - - - - 0 bounce
trace unix - - - - 0 bounce
verify unix - - - - 1 verify
flush unix n - - 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - - - - smtp
relay unix - - - - - smtp
# -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - - - - showq
error unix - - - - - error
retry unix - - - - - error
discard unix - - - - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - - - - lmtp
anvil unix - - - - 1 anvil
scache unix - - - - 1 scache
# Interfaces to non-Postfix software. Be sure to examine the manual
# pages of the non-Postfix software to find out what options it wants.
# Many of the following services use the Postfix pipe(8) delivery
# agent. See the pipe(8) man page for information about ${recipient}
# and other message envelope options.
# maildrop. See the Postfix MAILDROP_README file for details.
# Also specify in main.cf: maildrop_destination_recipient_limit=1
maildrop unix - n n - - pipe
flags=DRhu user=vmail argv=/usr/bin/maildrop -d ${recipient}
# Recent Cyrus versions can use the existing "lmtp" master.cf entry.
# Specify in cyrus.conf:
# lmtp cmd="lmtpd -a" listen="localhost:lmtp" proto=tcp4
# Specify in main.cf one or more of the following:
# mailbox_transport = lmtp:inet:localhost
# virtual_transport = lmtp:inet:localhost
# Cyrus 2.1.5 (Amos Gouaux)
# Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus unix - n n - - pipe
# user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
# Old example of delivery via Cyrus.
#old-cyrus unix - n n - - pipe
# flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
# See the Postfix UUCP_README file for configuration details.
uucp unix - n n - - pipe
flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
# Other external delivery methods.
ifmail unix - n n - - pipe
flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp unix - n n - - pipe
flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix - n n - 2 pipe
flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman unix - n n - - pipe flags=R user=list:list argv=/usr/lib/plesk-9.0/postfix-mailman ${nexthop} ${user} ${recipient}
plesk_virtual unix - n n - - pipe flags=DORhu user=popuser:popuser argv=/usr/lib/plesk-9.0/postfix-local -f ${sender} -d ${recipient} -p /var/qmail/mailnames
pickup fifo n - - 60 1 pickup
plesk_saslauthd unix y y y - 1 plesk_saslauthd status=5 listen=6 dbpath=/plesk/passwd.db
qmgr fifo n - n 1 1 qmgr
smtps inet n - - - - smtpd -o smtpd_tls_wrappermode=yes
plesk-agencemca.com-46.105.83.146- unix - n n - - smtp -o smtp_bind_address=46.105.83.146 -o smtp_bind_address6= -o smtp_address_preference=ipv4 -o smtp_helo_name=agencemca.com
plesk-mca-group.fr-46.105.83.147- unix - n n - - smtp -o smtp_bind_address=46.105.83.147 -o smtp_bind_address6= -o smtp_address_preference=ipv4 -o smtp_helo_name=mca-group.fr
plesk-serveur-mca.pro-149.202.199.25- unix - n n - - smtp -o smtp_bind_address=149.202.199.25 -o smtp_bind_address6= -o smtp_address_preference=ipv4 -o smtp_helo_name=serveur-mca.pro
I've this error (sorry in french) from outlook 2013 : Envoi du message de test de la messagerie : Aucune des méthodes d'authentification prises en charge par ce client ne l'est par votre serveur.
But i've no SSL activated on this connection, i'm connected with port 110 and 25 for smtp
In fact i've another problem : windows live mail !
Windows live mail haven't "authentification automatic" in setting an continue to refuse smtp send : error 454 Relay access denied...
Can you help me for that ?
What settings are you using to connect? I haven't used Live Mail for some time.
With Outlook...
imap SSL 993
imap TLS 143
smtp SSL 465
smtp TLS 587
And have you set Relay options in...
Plesk -> Tools & Settings -> Mail Server Settings
"Authorization is required" and ticked SMTP
And I don't see "mynetworks" in your main.cf...
Code:
mynetworks = 127.0.0.0/8, [::1]/128, your_ip/32
I guess that may be sanitized.
Anyway hope it helps
Kind regards
Lloyd
Ok i've but empty, i add all ips.
I need to add ip in smtpd_authorized_xforward_hosts = 127.0.0.0/8 [::1]/128 ?
are you sure for comma because smtpd_authorized_xforward_hosts haven't comma
Ok on one server, it's ok... if use outlook 2013 with automatic ssl on smtp
But on other plesk serveur, webmail it's ok, but with any client, i've an error on pop3 and imap on smtp... can't connect
Always ubuntu, plesk 12.5.30 same configuration...
Thx that's can help, but it's not fully functionnaly... postfix and plesk it's not fully compatible...
