Problem with vhost(svn)
Rainbowsix3
Hi.
I try to make my own SVN repository but i have problem with the vhost.conf
i have a subdomain "svn.rainbow-six3.co" over it i will access to my svn server. So i created a vhost.conf in the folder /var/www/vhost/rainbow-six3.com/subdomains/svn/conf/vhost.conf and run the reconfiguration "/usr/local/psa/admin/sbin/httpdmng --reconfigure-all"
But Plesk ignore my vhost. When i call my subdomain i get a 403 Forbidden error(i have no data in the folder).
my vhost.conf:
<Location />
DAV svn
SVNPath /var/local/svn
SVNParentPath /var/local/svn
SVNListParentPath on
</Location>
Hello,
Can you please place a one test index page in your /var/www/vhosts/rainbow-six3.com/subdomains/svn/ directory and check your site again.
[Tue Oct 15 09:56:51 2013] [error] [client 83.144.247.131] Directory index forbidden by Options directive: /var/www/vhosts/rainbow-six3.com/subdomains/svn/
Hello,
Okay, You will have to enable directory indexing with "Options +Indexes" directive for the domain vhost.conf file, Once you add it you can delete your test index page from your domain and check your site.
Hello, I have try to enable the directory indexing with the .htaccess but then i see only the foldercontent and when i try to enable the directory indexing with the vhost.conf(Plesk How to) i get the 403 Forbidden error.
I have run reconfiguration "/usr/local/psa/admin/sbin/httpdmng --reconfigure-all"
I think my Plesk ignore my vhost config. Then when i add the svn settings in the /etc/apache2/mode-enable/dav_svn.conf then the svn works fine, but then you have access to the svn over all my domains.
Hello,
The vhost.conf has these rights:
/var/www/vhosts/rainbow-six3.com/subdomains/svn/conf
-rw-r--r-- 1 www-data psacln 328 Oct 16 16:37 vhost.conf
and when i access over the port 7080 i get the 403 forbidden error too.
Can someone tell me, which is the correct path for the vhost.conf??
