Hello,
I'm having some problems after a RHEL5 (now 5.1) upgrade (yum).
The first problem was related to "bind". It wasn't starting anymore.
After some research I have managed to make it work, removing bind-suexec (or something like that - "rpm -e bind-suexec") and adjusting the "/etc/named.conf" file:
directory "/var/named/run-root/var/";
auth-nxdomain no;
pid-file "/var/run/named/named.pid";
(The paths were changed).
I don't know which step make it work, so if you are having this problem, try to adjust "named.conf" first.
The second problem is with IMAP.
Horde and SquirrelMail are not working anymore.
I found a lot of threads at this forum about IMAP problems, but I couldn't find a solution.
The problem is with IMAP itself, not with any Webmail.
IMAP is not working correctly in a simple telnet test:
telnet localhost 143
Trying 127.0.0.1...
Connected to localhost.localdomain (127.0.0.1).
Escape character is '^]'.
* OK [CAPABILITY IMAP4rev1 UIDPLUS CHILDREN NAMESPACE THREAD=ORDEREDSUBJECT THREAD=REFERENCES SORT QUOTA IDLE ACL ACL2=UNION STARTTLS] Courier-IMAP ready. Copyright 1998-2004 Double Precision, Inc. See COPYING for distribution information.
AAA LOGIN [email protected] password
Connection closed by foreign host.
If I enter a wrong password, I have a different behavior:
AAA LOGIN [email protected] wrong-password
LOGIN NO Error in IMAP command received by server.
So it looks like an authentication problem.
"ps aux | grep imap" returns this:
/usr/lib/courier-imap/couriertcpd -address=0 -stderrlogger=/usr/sbin/courierlogger -stderrloggername=imapd -maxprocs=40 -maxperip=4 -pid=/var/run/imapd.pid -nodnslookup -noidentlookup 143 /usr/sbin/imaplogin /usr/lib/courier-imap/authlib/authpsa /usr/bin/imapd Maildir
Here you can see an "authpsa" parameter. Can the problem be related to this authentication "module"?
Can anyone help me?
Thank you!
Alexandre
auth-nxdomain no;
Trying 127.0.0.1...
Can anyone help me?
Thank you!
Alexandre
